User Tag List
Results 1 to 2 of 2
Thread: 501.15(a)(4) Exception 1
  1. #1
    Join Date
    Aug 2011
    NH
    Posts
    252
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This Exception says that for metal conduit containing no unions, couplings, boxes or fittings, that passes completely through a Div 1 location with no fittings installed within 12" of class boundary, shall not require a conduit seal if the termination points of the unbroken conduit are in an unclassified location.
    What is considered the 'termination points of the unbroken conduit'? The first fitting/coupling? or the end of the conduit run?
  2. #2
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,704
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You need to meet both conditions. The ends of the conduit in a box (terminations) must be unclassified, AND all couplings must be at least 12" away from the classified area.
    Pet Peeve: There is plenty of room in the subject line for the Code reference AND a brief description of the issue.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
