User Tag List
Results 1 to 3 of 3
Thread: what sort of coverage can I expect from certain wall packs
  1. #1
    Join Date
    Feb 2016
    mi
    Posts
    80
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm trying to replace a light pole with wall packs on buildings near by. Is there an app or website that tells me about the coverage I can expect from a certain watt wallpack mounted at a certain height?
    Thanks
    Mielectrician
  2. #2
    Join Date
    Dec 2015
    Texas
    Posts
    194
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Many manufacturers have sample calculators (http://webtools.cooperindustries.com...478.1518463637) You would click on the IES file you want and select the 'calculator' looking image next to it. You can modify height and other things in it. The alternative method, would be to contact you local lighting rep and have them run the calculations. It sounds like the latter may be the better option as you're replacing a site light with a wall sconce.
  3. #3
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,471
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Download the IES files from the manufacturer and load them up in your favorite photometric program.
    It’s helpful to have the CAD file from your site & building drawings, but most of them have some option to draw out a simple site plan or make 3D shapes for your building.
    This is really the only way to do it and take out the guess work; and then you can see an actual representation of foot-candles at any given point.
    Brought to you by Carl's Jr. ©
Posting Permissions
  • You may not post replies
  • You may not edit your posts
