User Tag List
Results 1 to 10 of 10
Thread: EATON GFCI SGF15-M
  1. #1
    Join Date
    Nov 2017
    Houston
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    EATON GFCI SGF15-M
    I am installing an EATON SGF15-M gfci receptacle under the sink. I am trying to make it a split circuit but I can’t find the “break off” tab. Does this model receptacle not have a break off tab?
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,269
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have never seen a GFCI receptacle with break-off tabs.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,137
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I have never seen an Eaton Receptacle
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,137
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lpfam111 View Post
    Remember there is a line and load so there is no way to get 2 circuits from one Gfci. Install a 2 gang box and use 2 gfci's
  5. #5
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,929
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Push button resets are not allowed under sinks with cabinet doors, or behind cabinet doors at all.
    See "Readily Accessible" in new work code 210.8, and Replacement Code 406.4(D)
    Roger Ramjet NoFixNoPay
  6. #6
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,137
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ramsy View Post
    Yes they need to be readily accessible but it definitely arguable whether under a sink is readily accessible. IMO, if the receptacle is close to the front of the cabinet then it is considered readily accessible.
    I don't see anything that states it cannot be behind a door.
  7. #7
    Join Date
    Nov 2017
    Houston
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    There is a 2 gang box with 2 romex feeds. One is black red white gnd. That’s the one wired to the switch. The other romex is just black whit gnd but when I wire that to a second gfci it trips the breaker. The black red white works fine and operates by the switch.
  8. #8
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,929
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I like your interpretation, but the senior planner who instructs our local IAEI tells inspectors to red tag it, forcing the reset placement elsewhere.
    I believe he uses this to force kitchen remodels to upgrade the electrical service when older panels won't except a GFCI breaker.
  9. #9
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,137
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    You do realize that we are not allowed to help with diy projects. I know you are an ee but unless you are qualified as an electrician then we cannot help.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,120
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Eaton acquired Cooper.
    I live for today, I'm just a day behind.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
