User Tag List
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: Touching 120V wires
  1. #21
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by meternerd View Post
    If he really said "touching 110V," it tells me he doesn't know what he's talking about. There's no such thing as 110V anymore.....it's all 120V. Ditto for 115V.
    well, as old as I am, gonna call it 110, 120 or 115 at various times and not worry about it... same wiring, same appliances, no problems runnning everything as long as it is over 100 and under 150... lol... same with 208 to 245 for 240... just worry about 240 from split phase against 240 from single EU phase... still trying to learn if they are the same or different because even the big companies cannot tell me..lol... they all say different but electricians say it is all 240..lol..
    Student of electrical codes. Please Take others advice first.
  2. #22
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,918
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Adamjamma View Post
    Over the years, I've seen 110, 112, 113, 115, 117, 118, and 120.
    We've debated it ad nauseu; ​they're the same.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #23
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,125
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Adamjamma;1966454...
    just worry about 240 from split phase against 240 from single EU phase... still trying to learn if they are the same or different ...
    I would think you would need to be seriously disoriented to not know whether you were working in Europe or North America, and I would think the results of accidentally touching a hot wire would be quite different if it were (nominally) 120 volts to ground vs. (nominally) 230 volts to earth.
    If it were poorly-labeled and/or inconsistently color-coded, (not that that ever happens!) you might stumble onto a high-leg panel that looks just like a split-phase panel. Even if it was reasonable to test a 120-volt circuit by touch, you might be touching a 208-volt-to-ground circuit. That would be at least ∛x more of a tickle than you were expecting; maybe 3x the tickle because both the voltage & current are ∛ greater; maybe even a lot more than 3x if you exceed a dielectric threshold and get an avalanche.
    And that's not even considering miswired/misused panels or oddballs. I can imagine a 240-volt loadcenter used on 480 for expedience or economy.
    I've seen a few 60-0-60 panels in audio studios and instrument labs to minimize hum. 120-volt loads supplied by two-pole breakers.
    Quote Originally Posted by LarryFine View Post
    Over the years, I've seen 110, 112, 113, 115, 117, 118, and 120. ...
    "Over the years"? During air-conditioning season, I've seen that much variation in a day.
  4. #24
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,918
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by drcampbell View Post
    I'm talking about voltage ratings on equipment labels.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  5. #25
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,603
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When you write "∛" doesn't that mean cubed root of 3? Multiply that times 120 and you get about 173.
    How you used it didn't you intend it to mean square root of 3? Multiply that times 120 and you get about 208.
    I live for today, I'm just a day behind.
  6. #26
    Join Date
    Dec 2005
    Florida
    Posts
    414
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I first entered the trade, My JW was 69 years old. He had such thick callouses on his fingers, he would lick his first finger and thumb and touch the wires to see if they were hot. We did things differently in 1972! Well, he said, try it. Believe me, at 18, YOU DO NOT HAVE TO LICK YOUR FINGERS! It was the first and last time I did that! Off to get my first Wiggy!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
