User Tag List
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 33
Thread: Crock Pot Sparks
  1. #11
    Join Date
    Sep 2007
    MP89.5, Mason City Subdivision
    Posts
    227
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by al hildenbrand View Post
    Based upon your description, Charlie, it sounds like the cord, at the side of the crock pot, was a line to neutral short.
    The activity at the receptacle was probably a "series" event of a small point of contact between male and female that "fused", i.e., melted like a fuse element at the higher current in the short, giving rise to a plasma that would boil the metal to gas which would redeposit itself as the black mark.
    Dang...you're faster typing them I am.
    Gregg
    I'm just here for the pictures!
  2. #12
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,383
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks everyone. I agree that the wire shorted out at the point it enters the pot. The waste disposal company took it away yesterday, so it is too late for an autopsy. The damage to the prongs of the power cord is what led me to be concerned over the receptacle. We are just going to avoid using that outlet. It will be removed in about three weeks anyway.
    As an aside, the GC suggested, and my wife loved the idea, that no outlets be installed in the countertop wall space (i.e., in the wall itself). Instead, they will run something akin to Wiremold across the back of the underside of the upper cabinets, and put the receptacles there. That way the receptacles are not visible and will not interfere with anything she wants to store on the countertop. It recently occurred to me that the 20" limit would come into play. I need to look at the cabinetry plans to make sure this idea is workable.
    Edited to add: The plans show 19.5 inches from countertop surface to underside of upper cabinets.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  3. #13
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,301
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I could find that stuff in Jamaica I would run it myself but it is one of those things that one would b=need to import in a suitcase as no suppliers think the undercabinet lighting or outlets worth selling.
    Student of electrical codes. Please Take others advice first.
  4. #14
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,705
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When plugmold is used up at the cabinet it is usually because of fancy tile "backsplash" that the "decorator" doesn't want interrupted with receptacles.
    One can also put the receptacles horizontally and as high as possible under the cabinets (as long as still no more than 20" above counter) and it still might be acceptable to the decorator
    I live for today, I'm just a day behind.
  5. #15
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,061
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by charlie b View Post
    The key to effecting the end result lies with the depth of the under-cupboard valence in relationship to the sight line of a person seated at the lowest seat in the kitchen. The same goes for the under-cupboard lighting.
    Depending upon the arrangement of amenities in your new kitchen design, the lower lip of the cupboard (the valence) should hang down enough to break the sight line, of the lowest seated person, of the receptacles and under-cupboard lights.
    Another Al in Minnesota
  6. #16
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,383
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Our kitchen has no room for seating. My wife likes the idea of outlets out of sight mostly because it frees up wall space for the placement of appliances (either where stored or while in use).
  7. #17
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,061
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also consider any sight lines from seating in other areas, where one might be able to see the cabinetry. I understand there might not be any.
  8. #18
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,705
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why do you/your wife place appliances on the walls and not the counter?
  9. #19
    Join Date
    Feb 2013
    India
    Posts
    2,621
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Two days ago, my wife plugged in a crock pot (in the lower half of a duplex receptacle), turned it on, and saw sparks flying. The breaker tripped, there is black discoloration on the receptacle itself (I haven’t tried to clean it yet – it might just be on the surface), there is damage to the plug, and the wire entering the pot is almost completely burnt through.
    Question: Is there likely to be a safety hazard?
    Yes. Every electrical appliance should have at least a minimum insulation resistance. It should be checked periodically before plugging in.
  10. #20
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,705
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sahib View Post
    Every household kitchen needs a megohmeter in the cupboards
Posting Permissions
  • You may not post replies
  • You may not edit your posts
