User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: 3-way switch without travelers (radio)
  1. #1
    Join Date
    Oct 2018
    WA
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    I know they are available, Lutron I think.
    I am looking for the switches that can be installed where there is no 3-wire installed that can control one light or outlet from two locations.
    Is it the Maestro line? Casita? I just want two plain looking switches, does anyone know the part number? Google searches have come up with a lot of options but mostly I am seeing switches of more complexity than I need.
    thanks
  2. #2
    Join Date
    Oct 2017
    Fort Myers
    Posts
    23
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lutron Caseta is the way to go
    Quote Originally Posted by JoeNorm View Post
    Hello,
    thanks
    Lutron Caseta is the way to go.
    They have a dimmer/remote kit around $59.99. It is available at Home Depot Amazon and most suppliers.
    https://amzn.to/2Rp2lY2
    Name:  lutron caseta dimmer kit.jpg
    I would also buy the Wallplate Bracket for Pico Remote
    https://amzn.to/2SshjcZ
    There is also a Caseta Switch and two button remote.
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,137
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Best bet call Lutron help desk they are available 24-7. I am not sure they are available as standard switches.. May have to be Decora style
    1-(844) LUTRON1
    (588-7661)
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #4
    Join Date
    Oct 2018
    WA
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Decora would actually be preferred.
    What I meant by "plain" is just looking like a normal decora rocker switch. I don't need a dimmer, or a switch that has four different buttons on it.
    The one I have used is a simple click on, click off, at both switch locations
    thanks
  5. #5
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,047
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    thanks
    This is the switch you need. It is just an on/off RF switch. Basically the same as the Caseta without the other stuff. You use it with the Pico remote.
    https://www.1000bulbs.com/product/11...-PD5SDVWH.html
    If you aim at nothing, you will hit it every time!
  6. #6
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,425
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Be aware that not all LED lamps work with this control, you may need to install an incandescent even to get it programmed.
    Tom
    TBLO
  7. #7
    Join Date
    Oct 2017
    Fort Myers
    Posts
    23
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    No...
    You need to read the spec's on the LED light and the switch, to check and see if they are compatible. You may also have to test in your shop first, then go out to the job.
    Use the following website to see if the dimmer/switch is compatible.
    http://www.lutron.com/en-US/Pages/LEDCompatibilityTool/Compatibility.aspx
  8. #8
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,047
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The RF switch that I posted ships with what is called a MLC (minimum load capacitor). You tie it in anywhere in the circuit, line-neutral. I usually like to tie- in in the switch box. It puts a small load on for LED or even fluorescent. Same principle as adding a regular bulb.
    I don't automatically use them, only if the light doesn't work or work well with the switch.
    Let's just say I have a drawer full of them that I didn't need.
  9. #9
    Join Date
    Jun 2003
    Posts
    10,425
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cburke1111 View Post
    No...
    That may very well be good if you are the one supplying fixture, lamps, and controller, if not, take an incandescent along with you. Makes for an easier day.
    Tom
    TBLO
  10. #10
    Join Date
    Jun 2003
    Posts
    10,425
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Little Bill View Post
    That's nice! The last one we installed did not have that doodad. I think I sold it to them a year or so ago and they finally called to have it hooked up.
    Tom
    TBLO
Posting Permissions
  • You may not post replies
  • You may not edit your posts
