User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: RE: House built in 1982
  1. #1
    Join Date
    Dec 2018
    Palm Beach County FL
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I received a Notice of Violation from the Palm Beach County, FL building department that had the following code violations:
    1. 200.6 Grounds PBD Amendments to PBC 5th Edition (2014)
    2. 250.4 General requirements for grounding PBC Amendments to PBC 5th Edtion (2014)
    3. 250.6 Objectionable current PBC Amendments to PBC 5th Edition (2014)
    The house was constructed and received its CO in 1982. Should these items be grandfathered in and not be required to be updated to the 2014 code requirements?
    No construction is being done on the property.
    Thanks for your help.
    S. Herrick
    Attached Files Attached Files
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,438
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It is possible that this forum might not be of much service to you. You have family working in the industry, but you do not. So we aren't allowed to help you with planning or performing any work to correct any deficiencies. But since you are (at present, at least) only asking for applicable codes, I have approved your post.
    Please note that I am not able to read you attachments. They are of such low resolution that the text is illegible.
    In general, if an installation was in compliance with the codes that were in effect when it was built, it will not have to comply with revised versions of the code. A general exception to the so-called "grandfather rule" is that you can be forced to comply with current codes, if failure to do so represents a safety hazard. Improper grounding can be a safety concern.
    I am curious as to how and why a County inspector came to believe that they had a right to inspect the property and to issue violations, given that no construction project was in progress. Can you elaborate on this point?
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  3. #3
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,071
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Stuarth520 View Post
    S. Herrick
    I, too, found the attached PDFs unreadable.
    Above, the violations are Palm Beach County Amendments to the Palm Beach County 5th Edition . . . what? Statutes? Code?
    May I suggest getting the exact words, as published by Palm Beach, for these cited code violations. Can you share them with us, verbatum?
    Another Al in Minnesota
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,536
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In the absence of any construction work, all jurisdictions I have worked in do not require you to upgrade or alter anything that was legal at the time of original construction. Is this an inspection prior to sale? Some inspectors (erroneously, at least in NJ) think this gives them a second bite at the apple. Depending on the cost to comply, it may be worth pushing back.
  5. #5
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,071
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If the house is licensed rental property, the local jurisdiction may require periodic inspections within the terms of the licensing statutes. Here, a local "Minimum Electrical" standard is given force as local statute.
  6. #6
    Join Date
    Dec 2005
    Florida
    Posts
    409
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When does an inspector come to a house for no reason? There has to be more to this story.
  7. #7
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,536
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Gary11734 View Post
    In NJ the only time outside of construction that an inspector will set foot on the property is when it's sold. Then they do a CCO inspection. I think they are primarily looking for any unpermitted work that may have been done.
  8. #8
    Join Date
    Dec 2005
    Florida
    Posts
    409
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    Yes, that sounds OK. Well, I didn't see that or any other than "No Construction" was done. I would assume there is more to this story. Like a neighbor called or something, we don't have the facts too.
    It's hard enough to get them out of the car to do inspections when we call for one! lol Just kidding to any inspector here!
  9. #9
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,360
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I didn't read anything-lol- but if your house was installed to code when it was built then there should not be anything they can do about it
    Now, why were these people there checking the wiring? Something must have happened, IDK. Is the house being converted to something other than a single family dwelling. Was the install on the service change and never permitted? etc
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,997
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That also depends on the town, not every town requires a CCO many just inspect for smoke alarms.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
