User Tag List
Page 13 of 13 FirstFirst ... 3 11 12 13
Results 121 to 123 of 123
Thread: Will it trip the breaker?
  1. #121
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Gary11734 View Post
    Somewhere in this thread, I said the fuse would be considered the weakest link of the circuit...
    But with element running at near 4 times it's designed wattage, it may not be. The fuse is only seeing twice the current it sees at 120 volts, if it is a 750 watt toaster and has 15 amp fuses twice the normal operating current is still less than the 15 amp fuse rating, element is going to be the weak link in that situation.
  2. #122
    Join Date
    Dec 2005
    Florida
    Posts
    419
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    If I say that the fuse WILL be the weak link, I would assume the person that does the math will come up with the answer, which is over 100 percent of the breaker ampacity and trip.
    The question was based on whether someone would think the current would drop in half, not what the weakest link in the circuit was.
    Ok, the next post will be;..... This original question sucks! lol. Yes, I have heard this here often in this thread...
    Your above scenario sounds correct. The toaster element would be the wink link...
  3. #123
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,216
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Seems the question has been answered and the thread has come full circle. So looks like a good stopping point.
    If you aim at nothing, you will hit it every time!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
