User Tag List
Results 1 to 2 of 2
Thread: Tapping directly into grounding rod
  1. #1
    Join Date
    Jan 2019
    Royal Oak
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am interested in upgrading an existing outlet so that it is properly grounded. The outlet in question is running off of a 2-wire circuit along with one other outlet. The position of these outlets would make it rather difficult to run a wire through the walls and instead what I would like is to connect directly to the house's grounding electrode (a rod electrode in the ground). This rod electrode is located directly on the other side of an exterior wall from the concerned outlet and connection to it would be much simpler. My question is the following: Would this upgrade satisfy the NEC? Based on my own research, since I am grounding an existing receptacle the article that would apply to my grounding method is 250.130(c) and the first point of this text describes "(1) Any accessible point on the grounding electrode system as described in 250.50" as an acceptable grounding conductor. Going off of this information, it appears that my plan is in compliance but I am interested in a second opinion
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,355
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I am closing this thread, in accordance with the Forum Rules.
    This site is designed for:
    • Contractors
    • Electricians
    • Engineers
    • Inspectors
    • Instructors
    • Other electrically related individuals
    * This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
    If you feel this action to be in error, feel free to contact me via PM to explain.eminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
