User Tag List
Results 1 to 5 of 5
Thread: Blinking Deck Dots
  1. #1
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,598
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Blinking Deck Dots
    I installed a bunch of so called deck dots for a customer in their deck. They are very small LED lights that get wired back to a transformer/driver that plugs into a 120 volt receptacle. Recently the customer reports that after running for a few minutes they start to blink. I’m assuming the driver needs replacement. Any thoughts on this?
  2. #2
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,471
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Faulty or undersized LED driver
    Brought to you by Carl's Jr.
  3. #3
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,598
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brantmacga View Post
    I has worked for four years. Must be faulty. It came from supplier As a kit so I hope they sized it correctly.
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,734
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Anything that affects every light must be caused by a common component, i.e., the power supply.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,471
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Blinking Deck Dots
    Quote Originally Posted by mkgrady View Post
    In that case, I’d say the driver is faulty. But it wouldn’t hurt to make sure it’s not being driven too hard.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
