User Tag List
Results 1 to 5 of 5
Thread: Swimming Pool Fence Bonding - Aluminium Fence Insulated from ground
  1. #1
    Join Date
    Jan 2019
    South Australia, Australia
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    I work as a fencing installer for swimming pools in Australia. I have general knowledge of the requirements for metallic components of a fence that are within 1.2m of the waters edge to be bonded and grounded, however recently came across a job which raised some questions with me and was hoping someone would be able to help clarify.
    This job being - aluminium fencing panels which were supported by plastic fence posts, and hence the metallic components of the fence were completely insulated from the ground. In this case, would bonding and earthing still be required if the fence was within the specified distance from the water?
    Thanks
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,255
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The code does not give exception but IMO, the bonding seems unnecessary. The only reason I can see to bond it is that someday someone may install a wood post. That can be conductive.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,296
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it would fall under the same exception in the 18th edition of the BS7671 that the bonding of water and gas pipes now have.. since only plastic contacts the ground a bond not necessarily needed.. however, I would still bond the fence panels to ground anyway, just in case some idiot drags an electric cord through it, and that electric cord faults...
    You cannot fix stupid but sometimes you can take the five minutes to try to out think stupid...
    Student of electrical codes. Please Take others advice first.
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,255
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Gutters and aluminum windows are supposed to be bonded so it makes sense the fence should be also. I think what Adam said is correct. It is very possible someone would hand so xmas lights on the fence so there would be a possibility of energizing.
  5. #5
    Join Date
    Jan 2019
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the advice.
    I will still recommend the customer have the fence bonded as a precaution.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
