User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: push-on grounding clips
  1. #1
    Join Date
    Feb 2003
    Illinois
    Posts
    23,965
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are the push on grounding clips that can be used for box bonding as required by 250.148(C) listed items?
    If so, does anyone know what UL category covers them?
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,521
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    These NSI clips have a UL stamp on them.
    Roger
    Join Date
    Dec 2011
    Wisconsin
    Posts
    594
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by don_resqcapt19 View Post
    They are covered under UL category KDER.
  4. #4
    Join Date
    Feb 2003
    Illinois
    Posts
    23,965
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by packersparky View Post
    I thought they would be but when I look up Raco's part number for that clip, it does not show up in the list of part number that they have listed in the category.
    Don, Illinois
  5. #5
    Join Date
    Feb 2003
    Illinois
    Posts
    23,965
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by roger View Post
    Roger
    Thanks. However they can't be used in the field as they are UL Recognized and not UL listed.
    http://www.nsiindustries.com/UserFil...rounding17.pdf
    Don, Illinois
  6. #6
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,556
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I note they carry the “Listed” rather than “Recognized” UL mark on the clip itself.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2017 NEC unless otherwise noted.
  7. #7
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,297
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rbalex View Post
    It may be both listed and recognized.
    Bob
  8. #8
    Join Date
    Feb 2003
    Illinois
    Posts
    23,965
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by petersonra View Post
    It does not appear on the list of their products that are listed under that category.
    Don, Illinois
  9. #9
    Join Date
    Feb 2003
    Illinois
    Posts
    23,965
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is interesting as that part number is not on the list of UL listed parts under KDER.
    Don, Illinois
  10. #10
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,297
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    why don't you ask them?
    My guess is that it would be covered under option 7 in 250.8
    250.8 Connection of Grounding and Bonding Equipment.
    (A) Permitted Methods. Equipment grounding conductors,
    grounding electrode conductors, and bonding jumpers shall be
    connected by one or more of the following means:
    (1) Listed pressure connectors
    (2) Terminal bars
    (3) Pressure connectors listed as grounding and bonding
    equipment
    (4) Exothermic welding process
    (5) Machine screw-type fasteners that engage not less than
    two threads or are secured with a nut
    (6) Thread-forming machine screws that engage not less than
    two threads in the enclosure
    (7) Connections that are part of a listed assembly
    (8) Other listed means
    Listed assemblies can include assemblies that are field assembled. In any case, the code does not require ground screws to be listed, or terminal bars for that matter.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
