User Tag List
Results 1 to 7 of 7
Thread: PV Panel Mounting Specs
  1. #1
    Join Date
    Aug 2008
    San Francisco
    Posts
    756
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just happen to notice the wind damage to my neighbor's solar panels that were installed last year.
    Was wondering if there are any standards/ requirements whether federal or state with regard
    to anchoring/ mouting to prevent such wind damage to this equipment. I know with utility scale solar farm installations the tracking type of systems automatically go into a Lockdown mode to prevent damage beyond a certain wind speed but was
    curious about residential installations. Any comments would be appreciated.
    Attached Images Attached Images
    Am I in shape?? I get plenty of exercise pushing my luck!!
  2. #2
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,635
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ATSman View Post
    Unless the windstorm was of very unusual severity, I suspect shoddy workmanship.
  3. #3
    Join Date
    May 2011
    Posts
    4,956
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you actually know that those were blown off? They sure look like they were removed deliberately and stacked. For one thing the leads are disconnected from the optimizers. A couple times I've seen panels blown off the racking, both from installer error installing (or forgetting to install, in one case) end clamps. They tend to flip over on the panel next to them because of the way the leads keep them tethered.
    There hasn't been a storm in the bay area that could blow panels off properly installed Ironridge, which is what that appears to be. I wonder whether you caught someone in the middle of work to address a roof leak.
    As far as standards, I'm not quite sure how codes address solar specifically, but Ironridge design guidelines, for example, are based on ASCE 7-10, which is a standard building codes are also based on.
  4. #4
    Join Date
    Aug 2008
    San Francisco
    Posts
    756
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    Good point
    tks
    I will get back to you
  5. #5
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,635
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good catch. I agree; that doesn't look like windstorm damage to me.
  6. #6
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,283
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ggunn View Post
    agree. unless you have hurricane style winds, the mounts should hold.
    Bob
  7. #7
    Join Date
    Jan 2012
    CA
    Posts
    549
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    seen photos of roofing stripped off by hurricane force winds........but panels remain
Posting Permissions
  • You may not post replies
  • You may not edit your posts
