User Tag List
Results 1 to 2 of 2
Thread: Testing Bonding after the fact
  1. #1
    Join Date
    Feb 2019
    Macomb Twp, Michigan
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The cement decking around swimming pool was installed without first having an inspection by the electrical inspector. I (homeowner) observed that the wire grid was placed down and the copper wire connected to the grid and the ladder, etc. The township inspector says that the deck needs to be torn out because he cannot see that it was bonded. Is there a reliable test that can be done to demonstrate that the pool is properly bonded and grounded?
    Any help short of having to tear out all the concrete, is greatly appreciated.
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,472
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Duplicate. Closed. The discussion is here: https://forums.mikeholt.com/showthread.php?t=196250
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
