User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Wire insulation letters. Thhn
  1. #1
    Join Date
    Jul 2015
    el paso tx el paso
    Posts
    38
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey there. I can't find where in the code book it tells what the letters on conductor insulation. Like then. Thank you.
    Sent from my Moto G (4) using Tapatalk
  2. #2
    Join Date
    May 2010
    North of the 65 parallel
    Posts
    2,252
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Look at 310.104
    Without data you’re just another person with an opinion – Edwards Deming
  3. #3
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,176
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Note that thhn auto-corrects to then.
  4. #4
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,436
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You mean what the letters actually mean / stand for ?
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,627
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by chuckgassmannm View Post
    310.104 gives you some idea but doesn't exactly tell you every detail either.
    A few common things:
    T: thrermoplastic
    H: heat resistant
    W: moisture resistant
    N: Nylon jacket (mostly for gasoline and oil resistance)
    X: cross linked polyethylene
    M: machine tool wire
    R: rubber
    some combination examples:
    TW = thermoplastic, moisture resistant
    THW = thermoplastic, heat resistant (75C), moisture resistant
    THHN = thermoplastic, double heat resistand (90C), moisture resistant
    THWN = thermoplastic, heat resistant (75C), moisture resistant, nylon jacket
    Then you find a -2 sometimes this turns THWN-2 into same thing as THWN but with a 90C rating. For some reason they'd rather do that than call it THHWN.
    I live for today, I'm just a day behind.
  6. #6
    Join Date
    Jul 2015
    el paso tx el paso
    Posts
    38
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you. That does answer my question.
  7. #7
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,089
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The first place I can recall finding this being used goes back to the early decades of the 1900s and the NECs published then.
    Rubber insulated conductors were being perfected, using a largely synthetic compound that was mandated to contain at least (something like) 13% real rubber. Three different identifiers were used: R, H and W
    R = The basic 60 degree C, "rubber" insulation with a cotton weave slip that is impregnated with bituminous compounds and further coated with wax.
    H = Rubber insulation "Heat" rated for 75 degree C.
    HH = "High Heat" rubber insulation rated for 90 degree C.
    W = "Wet" moisture rated rubber insulation.
    The "T" came with the post World War II evolution of plastics and stands for "Thermoset Plastic."
    Another Al in Minnesota
  8. #8
    Join Date
    Feb 2003
    Illinois
    Posts
    24,057
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by al hildenbrand View Post
    The wires with "T" are thermoplastic and not thermoset.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  9. #9
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,436
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    "T" doesn't always mean thermoplastic. As in MTW (Machine Tool Wire).
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,627
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    Well then W doesn't always mean moisture resistant either
Posting Permissions
  • You may not post replies
  • You may not edit your posts
