User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Wall mounted fixtures
  1. #1
    Join Date
    Jan 2018
    California
    Posts
    46
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi All,
    Have any of you used round type junction boxes to mount to a light fixture? I have a product that is designed to be installed to a wall recessed junction box; this approach can not be accomplished for my installation. I'm looking to do a wall mount JB that will support a fixture and will run exposed conduits from JB to JB to provide power to the lights.
    Thanks
    EE
  2. #2
    Join Date
    Jul 2004
    Louisville, Kentucky
    Posts
    2,156
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think a picture might help to explain what you have or want to do. I'm not sure I understand your issue.
    Norb
  3. #3
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,670
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 1793 View Post
    I think he is wanting to mount a luminaire designed for mounting over a flush box to a surface mounted box. Not always an easy task.
    I live for today, I'm just a day behind.
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,759
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Maybe a siding plate?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,324
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by FaradayFF View Post
    Hi All,
    Thanks
    EE
    No, i usually mount the light to the junction box.
    All I can think of is a round outside bell box with conduit hubs.
    If you aim at nothing, you will hit it every time!
  6. #6
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,340
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, it's done all the time. Appearance issues may limit the style of light fixture that you want to use. Some have a nice round base the same as the 4" j-box. Of course, these are small and usually cheap.
    Sometimes a pancake box can be set inside of the wall finish so you still have a flush j-box, albeit a small one. Sometimes you just cut a deep hole and bury a full-size box, getting creative with supporting it, and doing a lot of work through that hole. Those two methods assume you can run the wire from the back or fish through the wall.
    One alternative may be to attach a large decorative spacer around your fixture base and the conduits and j-box go inside of it.
    Or you can just hang the big fixture on the little box, if weather isn't an issue getting through the back of the fixture.
    Why do these OP's always tell us "I have this fixture" and never tell us exactly what it is, like it's a big secret? Ideas are better and faster when we can actually see the same thing.
  7. #7
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,759
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    There's always the vapor-tight fixtures:
    Larry B. Fine
    Master Electrician
    Richmond, VA
  8. #8
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,887
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I would see what size base the fixture has and then mount a 2x?? around the box so that the fixture fits flat to the board. Basically drill a 2x10 or whatever size is needed and notch for the conduit.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  9. #9
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,340
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also, some fixtures have a built-in hub for landing the conduit directly to the fixture itself.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,670
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MAC702 View Post
    More common for a "wall pack" but not for a fixture intended to mount over a flush box.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
