User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Sleeve Setting
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sleeve Setting
    What would be the best way/procedure to set these sleeves in poured concrete slab? They are going in a telecom closet? Thank you!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	22632   Click image for larger version.
  2. #2
    Join Date
    Feb 2003
    Huntsville Alabama
    Posts
    2,244
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unistrut supported to the for work or set on the metal decking. Depending on the construction type.
    Sent from my LGL157BL using Tapatalk
    Some people are like slinkies. They serve absolutely no useful purpose. But still put a smile on your face when pushed down a flight of stairs.
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by masterinbama View Post
    There will be metal decking.
  4. #4
    Join Date
    Feb 2003
    Huntsville Alabama
    Posts
    2,244
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Drill the decking and support them with strut laid flat on it.
  5. #5
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,164
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The space between them needs to be at least 3x the size of the largest aggregate. Did the architects allow for that?
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,238
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    If it's metal deck then are you drilling a hole in the metal for each sleeve?
    Quote Originally Posted by drcampbell View Post
    Typically these areas of the deck are designed to accommodate what is shown in the detail.
    Rob
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    so your asking about cutting metal deck? also how is the area or that slot accommodated for? thanks
    Sent from my SM-N960U using Tapatalk
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,238
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes, if there's a metal deck are you drilling a hole in the metal to allow the sleeve to penetrate to the ceiling below or are they leaving a big open slot to accommodate the sleeves?
    Rob
  9. #9
    Join Date
    Feb 2003
    Huntsville Alabama
    Posts
    2,244
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sometimes I wait and core drill
  10. #10
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well i wish i knew.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
