User Tag List
Results 1 to 9 of 9
Thread: LED Luminaire Advantages
  1. #1
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,175
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    When I started as a electrican some 40+ years ago, we had drum lights with incandescent lamps.These fixtures (back then they were fixtures) would be overlamped, and overheat the branch circuit NM. In 1984 NN-B was required as it had 90 C insulation.
    I recently installed a LED luminare from Commerical Electric, which is Home Depots house brand. 2 for $62, has 3 different color temp settings, light weight and easy to install, has a bar the luminare hangs from, wire it up and swing it into place. Dims really well.
    I only saw one or two non LED luminares at the big box.
    All in all the LED market has been an advantage to the industry. The CFLs were just a bump in the road....
    Moderator-Washington State
    Ancora Imparo
  2. #2
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If Edison was so smart, he should have just done these first.
  3. #3
    Join Date
    Feb 2016
    Illinois
    Posts
    1,427
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tom baker View Post
    How can the NM overheat if it has proper overcurrent protection?
    Edit: After I posted, you probably mean it overheats from the heat given off by the lamp, not electrical overload. duh!
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,750
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    LED's are great. certainly not perfect yet but great in so many ways. Now if the NEC would just ketchup and lower the VA for calculations
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  5. #5
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,511
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by electrofelon View Post
    I just wish engineers would stop specifying #12 on lighting circuits. And stop dividing circuits up like we’re still using fluorescents and incandescents. Heck I’ve done several projects lately that require FMC whips with #12 to a 60w fixture. Total waste of resources.
    Brought to you by Carl's Jr.
  6. #6
    Join Date
    Dec 2016
    Minneapolis, MN
    Posts
    347
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm with you on the VA requirements and conductor sizing. Super annoying. I recently bid a dentist office that called out for #10 homeruns and #12s after that. The place is like 75' square so voltage drop isn't a consideration. Waste of material.
    These remod LED lights are awesome, we use them all the time. They work great for soffit lighting outside where framing is always in the way. The one thing I noticed about them is (at least with the Lithonia version) they have very small outer edge lips so you almost need to cut the hole for it just a bit smaller than it calls for. There's very little room for error, unlike a regular can trim, which are a little more forgiving with the larger lip.
  7. #7
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    7,057
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the lighting load T24 calcs for california are pretty severe.
    and they limit what you can do. a lot.
    be careful what you ask for. y'all can codify LEED platinum lighting if you want to.
    complying with it is another thing.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  8. #8
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,730
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    My friend called me up and asked me if he could put 150 --10 watt led's on a 15 amp circuit. Imagine that.... unfortunately the code needs to catch up with the influx of LED's. A recessed can needs to be calculated as to the largest possible bulb for the fixture so if the fixture is rated for 75 watts then you cannot install 150 of them on a circuit....
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  9. #9
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,134
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree. The set of features keep getting stronger.
    Quote Originally Posted by Dennis Alwon View Post
    Dennis, this bears the need for a bit of scrutiny, in my opinion. A porcelain lampholder has a rating of 660 Watts. When I put porcelain lampholders inside a garage for the general area illumination, am I really going to be limited by that 660 Watts?
    Another Al in Minnesota
Posting Permissions
  • You may not post replies
  • You may not edit your posts
