User Tag List
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: Romex for DC run
  1. #21
    Join Date
    May 2014
    california
    Posts
    144
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Zee View Post
    Depending on specific eaves windows etc......Consider running down other side of house and across crawlspace....., sometimes an option....., sometimes too much work.
    This first one is my house and there is just no easy way to do it. And the cold water entrance is on the other side of the house, living room with 24’ vaulted ceiling in between. It’s going to be a peach. The bright side though, the path runs right past my fishtank and I’m going to drop off 2 X 20 amp circuits for the tank while I’m running the DC and cold water ground.
  2. #22
    Join Date
    May 2011
    Posts
    5,307
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by five.five-six View Post
    Remember you're not allowed to run PV DC with other circuits. Optimizer outputs are a grey area.
  3. #23
    Join Date
    May 2014
    california
    Posts
    144
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    I mean, If I’m running the PV DC in type MC, do I need to drill their own hole in the studs?
    I should probably contact the AHJ.
  4. #24
    Join Date
    May 2011
    Posts
    5,307
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's fine as long as you are in a different cable. The way you described it made me think you were perhaps planning to use a single conduit and pull multiple circuits.
  5. #25
    Join Date
    Sep 2006
    Great White North
    Posts
    1,649
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For anyone wanting to run Romex or where conduit is difficult or ugly: I recommend a micro-inverter system.
    No DC. All AC. You can run all the Romex you want.
    E.g. new construction: rough-in romex in walls if home-owner wants no conduit visible.
    You still can’t, unless you mean after you penetrate the roof.
    As for new construction, run pipe, not wires. I will never again build a house with non-permanent (read: the usual electric stuff that’s not changing until we have Mr. Fusion in the kitchen) wiring in the walls. I had a client 8 or 10 years ago who ran pipe all over the damned place and it was SO much nicer when he had solar put in than hoping the right sized wires went to all the right places for all the things he wanted.
    Julie in Austin
    Born to brew, forced to work ...
  6. #26
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    11,055
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tallgirl View Post
    You can't run Romex outside, of course, but you can run microinverter output circuits in Romex inside the building envelope. We do it all the time in many jurisdictions in Texas and have never failed an inspection because of it.
    Where've you been? It's been years.
  7. #27
    Join Date
    Sep 2006
    Great White North
    Posts
    1,649
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ggunn View Post
    You're not going to fail an inspection ... after you've penetrated the roof ... but solar, wired network cabling, and "home audio" are three things I think belong in pipe. NM is definitely cheaper and easier, but pipe is SO much easier to change your mind about.
    Let's see. I was working for a large solar company which imploded, after I was working for a solar manufacturer which got acquired, after I went almost broke trying to run my own solar company, and then I swore off solar. I forget which one of those things was when I stopped posting here. I also forget how many cool things I invented that are making electric grids work better there were since then. Okay, I don't know if any of them are being used, but I padded the crap out of my patent portfolio with things somewhere along the line.
    After bouncing around companies which have nothing to do with "electrical" I wound up at a company which makes things that control things that run on electricity.
    Julie in Austin
  8. #28
    Join Date
    May 2014
    california
    Posts
    144
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For C7 stuff, just use interduct. It’s a lot cheeper to run.
  9. #29
    Join Date
    Sep 2006
    Great White North
    Posts
    1,649
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That would also work. Mostly I mean that technology changes and replacing wiring which has been stapled to the insides of walls is a pain in the ass to replace.
    Solar projects last for decades -- there was one European research company I worked with about 5 years back which had arrays that were over 30 years old. There's been a lot of change in power conversion in the past 30 years.
    Julie in Austin
  10. #30
    Join Date
    May 2011
    Posts
    5,307
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If we're talking about this sort of thing ... (thread drift)...
    Run all the loads in the house through a large gutter or j-box adjacent to the MSP. Then when I come to install a battery system with a backup loads panel, I can install a the backup panel off the gutter and easily and cleanly switch over the loads to be backed up. And then the customer can change their mind about it too, and I can come back (for more money) and change them all again.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
