User Tag List
Results 1 to 6 of 6
Thread: lightolier 1103r
  1. #1
    Join Date
    Sep 2013
    Massachusetts
    Posts
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    lightolier 1103r
    Has anyone heard of an LED retro trim for a 6" lightolier with the floating socket?
    Sent from my SM-G975U using Tapatalk
  2. #2
    Join Date
    Mar 2003
    New England
    Posts
    13,938
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They exist but are very expensive. Your best bet is to install Sylvania's retrofit sleeve for the Lightolier housings and use a regular LED trim.
  3. #3
    Join Date
    Sep 2013
    Massachusetts
    Posts
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am wondering if a 6" LED wafer light will work with the existing hole. Since there isn't a can and just a housing
  4. #4
    Join Date
    Dec 2016
    Minneapolis, MN
    Posts
    347
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just did a job where we retrofitted 130 existing Lightoliers with floating sockets to these:
    http://www.cooperindustries.com/cont...8136en-sss.pdf
    Then we installed these:
    http://www.cooperindustries.com/cont...8042en-sss.pdf
    Turned out great, made a lot of money!
  5. #5
    Join Date
    Mar 2003
    New England
    Posts
    13,938
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MNSparky View Post
    The Sylvania retrofit rings are about $5 at the wholesaler and install faster than those Halo retrofit cans.
  6. #6
    Join Date
    Sep 2013
    Massachusetts
    Posts
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you. I was able to use a Westinghouse retro fit LED trim. How I made it work was I bent the clamps down about 90⁰ and they held perfectly snug!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
