User Tag List
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
Thread: sp st momentary contact that looks like sp
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,664
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hbiss View Post
    Why do I have to go searching for the spec sheet? https://image.ylighting.com/is/conte...161751_specpdf
    Looks like they are calling for an on-off SPST switch and a momentary NO push button. They have them separate on a single plate. 4 conductors from the fixture.
    I don't know how you would do that with a single switch.
    -Hal
    YOu don't, but could still do it with two separate switches.
    I live for today, I'm just a day behind.
  2. #22
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,664
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wyreman View Post
    because my question was much simpler
    and that is I believe
    Somebody has installed a
    2p momentary contact switch w center off
    Never seen such a thing in a Decora style switch, but that doesn't mean there isn't one out there either, but if so simple fix is to tie the two outputs together then no matter which way you push the switch, you get same output signal and it sort of functions same as a spring return push button would.
  3. #23
    Join Date
    Jun 2003
    Posts
    11,417
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a small HMI and PLC that would work well. Touch the Scene you want and walk away. Probably a phone app out there some place.
    Tom
    TBLO
  4. #24
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,842
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    Well, yeah. Isn't that what I said?
    It seems to me that the fixture, at $2800, would come with the control switches and plate.
    -Hal
  5. #25
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    -Hal
    I have an X10 switch that combines on/off and dimming in a single button. Push-on/Push-off. Push & hold to dim or brighten.
  6. #26
    Join Date
    Jun 2003
    Posts
    4,842
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PaulMmn View Post
    That's not two switches. It's a dimmer.
    -Hal
  7. #27
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,664
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    -Hal
    Going a little deeper in technicalities, it has some sort of mini processor inside, that switch is just an input device to the whole assembly. It is programmed to do different things depending on duration of the input signal. The switch mechanism itself doesn't directly switch the output of the assembly like it does for the switches that are the main topic of this conversation are typically used.
  8. #28
    Join Date
    Jun 2003
    Posts
    4,842
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Actually this operates the same way except that the switches are remote from the fixture and the fixture contains the mini-processor. I believe the switches are LV. They control the mini-processor through 4 conductors. Line voltage is run directly to the fixture.
    -Hal
  9. #29
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,879
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    190420-1943 EDT
    If low voltage logic signals are being switched, then ordinary switch contacts for 120 V can be a poor choice.
  10. #30
    Join Date
    Jun 2003
    Posts
    4,842
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Another good point to consider.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
