User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Riser Tap
  1. #11
    Join Date
    Sep 2012
    NJ
    Posts
    2,556
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would bus detail make sense instead of tap? Someone mentioned there might not be room for the taps connectors. Not sure that makes sense. The box would have to be sized for conduits entering top and bottom and also entering the right side, correct?
    Sent from my SM-N960U using Tapatalk
  2. #12
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,329
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Bus detail for a #6 tap? Probably not. Yes the box needs to be sized for the riser conduits regardless of whether or not you use bus detail.
    Rob
  3. #13
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    686
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by augie47 View Post
    I didn't see one that has a #600 run and a #6 tap.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
