User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Riser Tap
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Riser Tap
    Someone else is running the #600 riser. We are just running from the tap box to the panel( we are doing the tap). This happens at about 5 floors. I know of the Ilsco “port” type taps but couldn’t the piercing type be used to and eliminate the need to cut wires? Actually not sure the crimping type will work as I'm tapping #600 to #6 and they don't list that size range. Thanks.
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2010
    Bowmanville, Canada
    Posts
    103
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is your question?
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,314
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes insulation piercing taps will work if you can find them in the correct range.
    Rob
  4. #4
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My other question. If you used a ported tap block you would have to cut the wire where your making the tap. If using insulation piercing you would not need to cut wire. Wouldn't you want to avoid cutting wire and jut pull wire point to point? Thanks
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,314
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    You either have to cut it or feed it through the tap if the hole is large enough to allow the insulated conductor to pass through.
    Rob
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Your referring to these that the wire can be feed straight thru?
    https://commerce.ilsco.com/e2wShoppi...512:3100012872
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,314
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Yes if the hole is larger enough for the insulated conductor to pass through but since the riser will be installed by someone else that won't work for you. I would use insulation piercing taps if you cannot find the proper wire range you might need to make your tap conductors a bit larger.
    Rob
  8. #8
    Join Date
    Jun 2010
    Bowmanville, Canada
    Posts
    103
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does anyone have a link for the piercing tap connectors?
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,602
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  10. #10
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by augie47 View Post
    Thanks
    Sent from my SM-N960U using Tapatalk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
