User Tag List
Results 1 to 2 of 2
Thread: Grounding dry type 120/208–277/480v transformers
  1. #1
    Join Date
    Apr 2019
    Plano TX Collin
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have an inspector that says you must use grounding type bushing on conduits entering transformer.
    is this a new code requirement I’m not aware of because I have always used plastic bushings
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,222
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Unless there are concentric or eccentric KO's and it's over 250 volts to ground they are not required. The GEC in a metal raceway is a different story.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
