User Tag List
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
Thread: Display mounting
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Display mounting
    Have a bunch of ceiling hung displays that I need to mount. They are about 3'x8' and weight about 500 lbs. What would one use to life something that heavy up to height being mounted? Thanks.
    Sent from my SM-N960U using Tapatalk
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,401
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Depends on the construction. You might need structural engineering with that much weight.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,319
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    You could use on of these, good for 1000#'s.
    Rob
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,401
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I guess I misunderstood the question.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,289
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    If you otherwise already have scissor lift or fork lift on the site (or on the level working on) I imagine many just use those, but otherwise Infinity's lift is a nice choice if you are going to bring something in for the purpose, and is easier to get to upper floors than a scissor or fork lift. HVAC guys will likely have one if you need to know where to find one.
    I live for today, I'm just a day behind.
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,555
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, what are they called? Wonder how high they go.
  7. #7
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you have a bunch of these to hang, would it be easier to hire a rigging company? They're used to lifting heavy things to strange places...
  8. #8
    Join Date
    Dec 2016
    Minneapolis, MN
    Posts
    347
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've always heard these called a "genie lift" although I'm sure it's not the real name. We have an older one we use to lift ceiling hung transformers, it works pretty well. I believe ours will lift a 500lb transformer to a height of 14' to the bottom (where the forks are).
    I know they are fairly cheap to rent and will fit inside a full size van.
  9. #9
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MNSparky View Post
    Genie is one brand, maybe the first (https://www.genielift.com/). They're like Kleenex (R) (Kimberly-Clark). Or Romex (R) (Southwire (originally General Cable)).
  10. #10
    Join Date
    Jul 2003
    MA
    Posts
    2,174
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is no way he didn’t know about the lift.
    He is trolling you guys. Why don’t you see it?
    Tim
    Master Electrician
    New England
    Yesterday's Technology at Tomorrow's Prices
Posting Permissions
  • You may not post replies
  • You may not edit your posts
