User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Sizing loads to industrial machinery
  1. #11
    Join Date
    Jan 2019
    UK
    Posts
    477
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    Got a letter/number punch set with a "." in it
    Maybe nail on head ?
  2. #12
    Join Date
    May 2017
    SCV Ca, USA
    Posts
    597
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mark1990 View Post
    A little more detail on the machine. The prints call out several options not installed, totaling 33hp. Motors that are utilized are 27.5 kw servo and a 7.2 kw servo, along with a 7.5 kva transformer, for some 120 v loads. Maybe the nameplate includes the never installed options? My main question is, does the code allow me to run a smaller feed than the nameplate calls for? I dont see this anywhere in article 670. Any help is appreciated . Thank you
    This comment is based on your (purported) details notwithstanding other details you provided (eg) 192 FLA etc.
    The 33 HP name plate does make sense for existing #10 wiring
    I surmise this is a press trim guillotine type cutter?
    Most of this type machines are based on the GENEVA mechanism (i.e.) only one motor is running all the time while other motors that comprise the whole unit like indexing servos--only operate when called for. And when they do--they only operate momentarily.
    Typical machines found in book binding and CNC machines.
    Using the as-built info would resolve your dilemma.
    (Touring the Biomass Generating Plant in Norway)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
