User Tag List
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: 20' aluminum light pole what size Sono tube
  1. #21
    Join Date
    Mar 2003
    New York
    Posts
    1,940
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Could be guyed.
    Also are connected to each other.
  2. #22
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,565
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Yes, but they're 1/3 in the ground in relatively snug-fitting holes, not tamped earth.
    They don't put that much of them in the ground here. That would be a 13 foot deep hole for a 40 foot pole, and only 27 of it would be above grade.
    Guy wires are partially for the sake of the base, but also are for lateral strain relief on pole itself from conductor load.
    I live for today, I'm just a day behind.
  3. #23
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,718
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    Exactly right.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  4. #24
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,565
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exactly right.
    So you are saying most the distribution poles where you are (which typically are at least going to have ~ 30 above grade are planted 13 feet deep? I can't tell you exactly how deep they are around here, but I'd bet few are any deeper than 8 -10 feet with majority of those being closer to 8 instead of 10. Even in the sand areas.
  5. #25
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,718
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That's what my friend the EE who is well versed in power distribution systems tells me.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  6. #26
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,565
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe you have different combination of expected wind speeds, soil conditions, etc than we do that justifies this. I don't think most the POCO trucks around here even have digger auger that will go that deep. Not saying they can't install a longer one or some kind of extension but what is typically mounted on the trucks won't go that deep as is. I've watched them set a lot of poles over the years.
    Now maybe if they are setting even taller transmission poles they might go deeper, but I don't see that up close or for that matter that often period.
  7. #27
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,718
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I may have understood him, but I am seeing answers ranging from agreeing with me to 10% of the pole plus 2 feet.
    https://forums.mikeholt.com/showthread.php?t=111308
    Larry B. Fine
    Master Electrician
    Richmond, VA
  8. #28
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,565
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    One of them suggested 1/3 the length of the pole.
    50 foot long pole, 16.7 feet in the ground, 33.3 above ground
Posting Permissions
  • You may not post replies
  • You may not edit your posts
