User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Remote desktop
  1. #1
    Join Date
    Jun 2003
    Posts
    11,419
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Remote desktop
    Occasionally I use Remote Desktop to control my Main Office Computer when my office help is gone. This seems to be quicker than when I sit at that computer. Especially if I am using QB on the MOC. Why?
    We we are on the same office network.
    Tom
    TBLO
  2. #2
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Where are the 2 computers in relation to each other? Same building, on the same local network? Across the state; your RDP session uses The Internet to make the connection??
    What are the screen resolutions of the 2 computers? Do you have more than 1 monitor at one or both systems?
    Do you have an 'active' screen saver or backdrop screen on your main computer? Lots of sounds? Usually, RDP does not bring the sound and background screens through to the computer running the RDP session-- that's one less thing to process.
    Do you enlarge the window you're working in to take the full screen? If the computer doesn't have to keep refreshing the other windows, it can dedicate more effort to what you're working on.
    Is everyone else at home when you notice the speed increase? Have you noticed the speed is not faster at all times of the day, say, for example, mid-morning when everyone's pounding away at their machines to get work done?
  3. #3
    Join Date
    Jun 2003
    Posts
    11,419
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PaulMmn View Post
    Where are the 2 computers in relation to each other? Same building, on the same local network? Across the state; your RDP session uses The Internet to make the connection? 10ft distance , 50' via cat 5 & office network switch.
    What are the screen resolutions of the 2 computers? Recommended defaults. Do you have more than 1 monitor at one or both systems? One monitor hers, two @ mine.
    Do you have an 'active' screen saver or backdrop screen on your main computer? Lots of sounds? Usually, RDP does not bring the sound and background screens through to the computer running the RDP session-- that's one less thing to process? When I log on, all that stuff on hers is off. I could have several spreadsheets, PLC & HMI programing along with email and MHs formum all running on mine.
    Do you enlarge the window you're working in to take the full screen? It is full screen on the 2nd monitor If the computer doesn't have to keep refreshing the other windows, it can dedicate more effort to what you're working on.
    Is everyone else at home when you notice the speed increase? Have you noticed the speed is not faster at all times of the day, say, for example, mid-morning when everyone's pounding away at their machines to get work done? N/A
    Not simple. Both computers are more than adequate in size and performance. Hers more storage and more memory. Processor speeds close enough.
    Tom
    TBLO
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,666
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Differences in display adapters and/or associated settings.
    Other running applications on the host machine are affecting response to the display but not so much to the remote communications you are using?
    Obviously there must be sufficient processor, memory, etc. just something else you are not using when accessing remotely is either slower in general or bogged down.
    I live for today, I'm just a day behind.
  5. #5
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    I was going to say that more storage / more memory could be the key-- I know when I upgraded an old PC just by maxing out the memory, the performance jumped!
    But RDP is just a window through to your PC-- your PC is still doing all the work. The only advantage the PC you're working on gives you is 'more than enough' memory-- you're not using storage on her PC. But memory is just improving the connection between the PCs!
    Hard for me to tell what the reason is.
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,666
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not so sure about that, and at very least would depend on application and how it works. Desktop type applications AFAIK run on the machine they are installed on, you just are using different pathways than the local keyboard, mouse, display, etc. to be able to see and manipulate it.
    For a desktop application to run on your remote machine you would need that application installed on your machine, but you could use "remote desktop" to run anything on the machine you are accessing, it is just an extension of user interface components for the most part.
  7. #7
    Join Date
    Jun 2003
    Posts
    11,419
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    That is the deal. Running the software that is on her computer appears to run faster when I remote in from my desktop. I’ll have to try a couple reports and time them. ‘Appears’ is subjective
    Tom
    TBLO
  8. #8
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are you running the software on 'her' PC, or in the RDP window, which runs the software on your PC??
    If you're running the software on her PC, and just accessing the document on your PC, that explains it! Her PC, with more memory, will be able to keep more of the program and your data in memory and not have to waste time paging stuff onto and off of disk.
    I'm not familiar with QB software, but if it uses temporary storage on any convenient disk drive, the fact that she has more storage means you won't be cramped for space, since it will probably be using her disk drive.
  9. #9
    Join Date
    Jun 2003
    Posts
    11,419
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am accessing the software on her system and operating it from mine just as if I were sitting at her desk.
    Tom
    TBLO
  10. #10
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I understand what you're doing now...
    The Main Office Computer is on HER desk, and you're using a computer on YOUR desk and using RDP to access her computer and run QB on her computer.
    And the system seems faster when you use RDP, than when you sit at her desk and run the program there.
    Do I have it correct now??
Posting Permissions
  • You may not post replies
  • You may not edit your posts
