User Tag List
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
Thread: 2014 NEC, 406.4(D)(2) Non–Grounding-Type Receptacles.
  1. #11
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Agreed. It does require that the power source has a grounded conductor.
    Your comment bothers my Sense of Reality-- I thought the GFCI just sensed the difference between the outgoing current on the hot lead compared to the incoming current on the neutral lead. I didn't think it required a grounded conductor at the power source.
  2. #12
    Join Date
    Jan 2007
    Posts
    4,119
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PaulMmn View Post
    The neutral from the source is the Grounded Conductor and is required for proper operation of a Ground Fault Receptacle.
    JAP>
  3. #13
    Join Date
    Jan 2007
    Posts
    4,119
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't confuse "Grounded Conductor" or Neutral with an "Equipment Grounding Conductor".
    JAP>
  4. #14
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,391
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Without a grounded circuit conductor, a contact between a hot wire and a grounded surface will not create a current difference. The hot wire wouldn't carry more current than the neutral, because there is no pathway for current around the current-sensing ring that both line conductors pass through.
    Remember why plug-in GFCI testers don't work on non-grounding receptacles? It's because the plug-in tester has no access to the neutral ahead of the current-sensing ring, so it can't create an artificial shock condition using a resistor like the one used for testing inside GFCI receptacles and breakers.
    A GFCI device serves no purpose and will not function on a non-grounded power source.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #15
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How about a 240 volt GFCI-- Only neutral involved is in the breaker box to power the electronics in the GFCI. Black wire out, black wire in; no neutral anywhere; neither black is grounded. GFCI still knows when there's a fault.
    Several interesting threads from the fora:
    From https://www.ecmweb.com/content/think-gfci
    From closed thread https://forums.mikeholt.com/showthread.php?t=158467
    From closed thread https://forums.mikeholt.com/showthread.php?t=102515
    From closed thread https://forums.mikeholt.com/showthread.php?t=66292
  6. #16
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,175
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The Code Making panel determined it would be safer to have a non grounded outlet replaced by a GFCI than to have someone cut off the ground in the cord cap.
    Moderator-Washington State
    Ancora Imparo
  7. #17
    Join Date
    Jan 2007
    Posts
    4,119
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In that scenario the GFCI is monitoring the 2 phase conductors.
    JAP>
  8. #18
    Join Date
    Jan 2007
    Posts
    4,119
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Neutral connection in the Panel is needed to energize the electronics inside of it to allow it to do so.
    JAP>
  9. #19
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jap View Post
    The Neutral connection in the Panel is needed to energize the electronics inside of it to allow it to do so. JAP>
    Yes, but neither of the conductors the GFCI is monitoring is grounded. The neutral in the panel is just for the electronics.
    Likewise, for a 120 volt GFCI, it wouldn't care if either of the conductors it is monitoring are grounded or not. The 120 volt model wouldn't care if the electronics were powered by a 110-volt DC battery!
    IMHO.
  10. #20
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But that would just be a design issue of the electronics inside, not a fundamental function of how it works, right?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
