User Tag List
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
Thread: How do I site, or walk , as straight line to mark a conduit Run w/o a Survey Transit
  1. #11
    Join Date
    Feb 2003
    Fl
    Posts
    17,705
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Installer View Post
    well at least its 1" SCH 40 conduit so I don't have too worry too much. Now if it was 12 inch SCH 80
    Do you really think you will be able to achieve a perfectly straight conduit in a 400 foot underground run? Get close and put metallic burial tape in the trench, it can be located when ever needed.
    Roger
    Join Date
    Mar 2003
    Vermont
    Posts
    2,524
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Coppersmith View Post
    Take a laser level or pointer and set it at point A pointed at point B. Starting at point B, walk toward point A while verifying the laser dot is hitting you.
    just tec screw it to the diggers head.....~RJ~
  3. #13
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,736
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Exactly. Why does it need to be perfectly straight?? I've never even given that a thought with the miles of cable and pipe I buried. Get a pavement marker paint can and walking handle and start walking. Chances are you are going to have to go around something that's buried anyway.
    -Hal
  4. #14
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,223
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    He didn't say it needed to be perfectly straight. But, you do want to lay out a somewhat straight line for the backhoe operator. It's a lot easier to walk that line with the paint, than it is for him to just dig without it, especially since he may very well be driving backward while doing so. The idea in post #2 is usually more than sufficient.
  5. #15
    Join Date
    Mar 2003
    Vermont
    Posts
    2,524
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I keep a close watch on UG’s of mine
    I keep my eyes wide open all the time
    I know most diggers can’t dig straight lines
    Because it's mine, I walk the line
    I find it very easy to transit, tape or string
    I find myself admitting it’s just not their thing
    Yes, I'll submit that I've a tool for you
    As sure as night is dark and day is light
    There's just no way to make two wrongs a right
    And litigation proves only deep pockets right
    They've given me these codes to keep by my side
    But none of them will matter if they want my hide
    And it's a given that i'll never turn that tide
    ~R(w/apologies to the man in black)J~
  6. #16
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    7,063
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We're dropping 400' feet of 1 inch conduit into the ground. I have to mark a straight line line with a Marking Wand for the Utility Locate and the Backhoe.
    Best thing is to have someone set a survey transit up and watch me -if I wander out of the walking Path-I get a yell to correct my direction.
    Does anyone have any suggestions/ Follow a pickup with a steering wheel held dead center?
    Not the birightest question someone has ever posted on this forum, but I might get some helpful feedback.
    get some form string.
    drive a stick at each end of the run.
    pull the string tight between them.
    or, take a hilti or similar laser that can work
    horizontally, and set it up on the line.
    that is overkill, unless you have one handy,
    and don't have string.
    go buy some form string.
    it works fine on 700' ditches. buy less string.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  7. #17
    Join Date
    May 2014
    Marlborough, Massachusetts USA
    Posts
    399
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Posts #3, 4 and 5 are the simplest way to go as long as it's clear of brush and up and down hills. The laser and compass isn't a bad idea either.
  8. #18
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,066
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I think Roger has the simplest idea in post 2. Pick a point on the horizon and walk towards it.
    If you don't think too good, don't think too much.
  9. #19
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,538
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go to the hardware store and get a package of the white flags used to mark an 'invisible fence'. Walk the proposed route, landing a flag in the ground every 10 feet. When done, stand back and look. If any flag is 'out of line', go adjust it to where it needs to be.
    Leave the white flags in place to mark the route for when you call 811/One-Call.
  10. #20
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,600
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Someone asked why it needed to be straight, remember that the 360 degrees worth of bends is not just 90's or what ever, in 400' I've seen lots of runs that could possibly have more bending than allowed.
    I have one now in a much shorter run that has 4 90's and a long radius bend. Now I don't have to pull it and I'm not that big of "you know what" to call that, but.......
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
Posting Permissions
  • You may not post replies
  • You may not edit your posts
