User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: How do I site, or walk , as straight line to mark a conduit Run w/o a Survey Transit
  1. #1
    Join Date
    Feb 2018
    DesMoines, Washington
    Posts
    105
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We're dropping 400' feet of 1 inch conduit into the ground. I have to mark a straight line line with a Marking Wand for the Utility Locate and the Backhoe.
    Best thing is to have someone set a survey transit up and watch me -if I wander out of the walking Path-I get a yell to correct my direction.
    Does anyone have any suggestions/ Follow a pickup with a steering wheel held dead center?
    Not the birightest question someone has ever posted on this forum, but I might get some helpful feedback.
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,688
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Stand at point A, pick a landmark inline with point B and start walking. You can also use a compass.
    Roger
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,514
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How flat is the ground? Maybe just lay out a rope.
  4. #4
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    Or get a plumb bob with lots of string.
  5. #5
    Join Date
    Jun 2012
    NW Ohio
    Posts
    1,162
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I’ve used a bucket of pull string. Drive a stake at each end of where you want to go, tie string to one end, tighten and tie off at other end, then run your marker along the string.
    Cheap easy way to make a nice straight line. Finding someone who can run a trencher straight along that line........well maybe another story.
  6. #6
    Join Date
    Mar 2003
    Vermont
    Posts
    2,471
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I have yet to meet a digger that can dig a straight line.....~RJ~
  7. #7
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    2,395
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Take a laser level or pointer and set it at point A pointed at point B. Starting at point B, walk toward point A while verifying the laser dot is hitting you. Mark the ground with spray paint as you go. This procedure is best done when it's dark out.
    A string will bow. A laser will not.
  8. #8
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by roger View Post
    Roger
    Do not do this after drinking alcoholic beverages!!
  9. #9
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mopowr steve View Post
    It helps if you mow the grasses along the path of the string-- fewer snags to make the line crooked!
  10. #10
    Join Date
    Feb 2018
    Posts
    105
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well at least its 1" SCH 40 conduit so I don't have too worry too much. Now if it was 12 inch SCH 80
Posting Permissions
  • You may not post replies
  • You may not edit your posts
