User Tag List
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
Thread: Resistor Value in Journeyman Exam
  1. #21
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,461
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by five.five-six View Post
    Gold and silver are tolerances gold is 5% tolerance, silver is 10% tolerance and no band is 20% tolerance.
    Then there is the 1% which is white, Mil Spec or military grade.
    The 95% of people that you can't trust give the other 5% a bad name.
  2. #22
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,727
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I wonder whether they intentionally manufacture resistors to such close tolerances, or they make them, measure them, and mark them according to the tolerance for which they qualify.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #23
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    1% resistors are definitely manufactured differently. Among other things a different construction can be necessary to get a stability appropriate to the tolerance.
    I would not be surprised if 5% and 10% resistors came off the same production line.
    20% resistors might come off a different production line.
  4. #24
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    I suspect that if they're mixing carbon slurry for 1K resistors, and aiming for at least 20%, if they hit 1K on the nose, some of the 20% resistors are going to be a lot closer to 1K than the color bands admit to!
  5. #25
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,727
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PaulMmn View Post
    The important thing is that they're not outside the marked tolerance.
    I was wondering if they make a batch with a target resistance, then actually measure each one, and simply mark the ones that are within 1% as 1%, the ones between 1% and 5% as 5%, those between 5% and 10% as 10%, etc.
    That would virtually guarantee that, for example, a 10% resistor would never fall within 5% of the target value.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  6. #26
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    303
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nowadays with automated testing, they could mark each one individually. I suspect that in days of yore they'd check a representative sample, then mark the whole batch.
    I think I was looking for pairs of matched resistors for a project, and buying 1% was expensive. IIRC, I heard that if you get a strip of resistors from Parts-R-Us that all of the resistors in a row will pretty much match ohm for ohm (unless you get the place where one batch replaces another).
  7. #27
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,866
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    190521-0743 EDT
    I have never been involved in resistor manufacture. So in part my comments are guesses.
    In the carbon composition days a resistor was a mixture of carbon and filler molded into a block.
    In the 1920s this was a somewhat round bar with a wire wrapped around the bar near each end, then painted. The resistance would be whatever you got falling within some distribution curve. These would be sorted into tolerance bands. Pricing would be based on the probability of building within a band, and demand for a given tolerance. After some experience in what the distribution curve was the price would be set. Price would need to be somewhat of a constant. This means that the resulting distribution curve for 5% units is different than 10% units. Its also means that if demand for 5% units is not as high as expected that some 5% items will be marked as 10%. Probably the poorer 5% would go into the 10% mix. So distribution curves might not be very consistent.
    By 1940 carbon comp resistors had the wires molded into the carbon block, and an outer coating molded around that assembly.
    Wire wound resistors were available with tighter tolerances. Here number of turns could be adjusted to adjust resistance.
    Then came film resistors. These are a ceramic core with a film surface of a resistive material, carbon or metal. A spiral grove is cut around the resistor to determine resistance. Resistance can be moderately accurately adjusted by the length of the spiral. This can be adjusted during manufacture, and so one is less dependent upon the variabilities of the resistive mix. Sorting still may be done. 1% metal film resistors are close to the price of 5% carbon comp.
  8. #28
    Join Date
    May 2005
    Skokie, Illinois
    Posts
    42
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    EIA Resistor Color Code
    An old, old mnemonic for said color code is "Roy G. Biv.
    More here:
    https://www.google.com/search?q=eia+Resistor+Color+Code
    https://en.wikipedia.org/wiki/Electronic_color_code
    Best regards . . .
  9. #29
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,596
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Skokian View Post
    An old, old mnemonic for said color code is "Roy G. Biv......... .
    That's for the colors of a rainbow.
  10. #30
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,727
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    Larry B. Fine
    Master Electrician
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
