User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Light opinion
  1. #1
    Join Date
    Oct 2015
    US
    Posts
    994
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Light opinion
    Does anyone think it would be ridiculous to put a light on both sides of that back door with that one side being so narrow. Would one light look weird need some opinions
    Sent from my SM-G965U using Tapatalk
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,519
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    One light, perhaps with multiple sockets/globes, centered above the door.
    Or, if there will be a deck as wide as the house, a flood, higher and centered on the house.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,268
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    All I have is "light opinions" I'm all out of "heavy ones"!
    What is that siding block for between the top windows and the doors below?
    Looks like for a light to me.
    Anyway, I was thinking the same as Larry, one, centered above the door.
    If you aim at nothing, you will hit it every time!
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,519
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Little Bill View Post
    You're right; the center one even has a hole.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  5. #5
    Join Date
    Oct 2015
    US
    Posts
    994
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I was planning on putting a nice led flood for when iwant to light up the yard, the sconces or sconce ,I was thinking more for everyday
  6. #6
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,519
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    In that case, a white coach lantern style.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  7. #7
    Join Date
    Mar 2003
    Vermont
    Posts
    2,524
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    so, a door light, a yard light, and two soffit lights? ~S~
  8. #8
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,736
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    What's that all the way up under the eves in the soffit? Looks like two recessed lights??
    -Hal
  9. #9
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,787
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How is anyone, including you, supposed to get any work done with all the construction debris laying around?
  10. #10
    Join Date
    Oct 2015
    US
    Posts
    994
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Yes soffit lights
Posting Permissions
  • You may not post replies
  • You may not edit your posts
