User Tag List
Results 1 to 2 of 2
Thread: Nec 2014 Articles 250.64(D)(3) and 250.53(D)(2)
  1. #1
    Join Date
    Jun 2018
    Glen bunie, md, us
    Posts
    499
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Attached sketch shows service entrance conductors going into trough. In the trough has ground bar which has supply side bonding jumper to trough enclosure and one grounding electrode conductor going to underground metal water pipe and other is a bonding jumper going to ground rods from the ground bar. The ground bar then has supply side bonding jumper and neutral going to each service disconnects as shown.
    Question is does the attached sketch comply per Nec 2014 Articles 250.64(D)(3) and 250.53(D)(2)?
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    17,692
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Post the attached sketch in the correct orientation in a new thread.
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
