User Tag List
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: Chiller Feeder Calculation
  1. #21
    Join Date
    Feb 2013
    India
    Posts
    2,713
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    How about some NEC references for any of that??
    My only reference is this article:
    https://www.apc.com/salestools/KSIH-6Y6UU5/KSIH-6Y6UU5_R0_EN.pdf
  2. #22
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,741
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sahib View Post
    Please try to stay on topic. The OP was about the NEC load calculation, so it doesn't matter what you think is overkill or what might/should be or if the compressor has polka dots on it.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  3. #23
    Join Date
    Feb 2013
    India
    Posts
    2,713
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I do not believe the article in my last post is against the intent of NEC or is not on topic.
  4. #24
    Join Date
    Feb 2003
    Connecticut
    Posts
    3,534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The article isn't relevant to Chillers. Nor does it completely follow the NEC.
  5. #25
    Join Date
    Feb 2013
    India
    Posts
    2,713
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by david luchini View Post
    Please clarify, if possible.
    Quote Originally Posted by David luchini View Post
    That is AHJ's call.
  6. #26
    Join Date
    Feb 2003
    Connecticut
    Posts
    3,534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The original question was about Chillers. The article you linked is about Air Conditioners.
    That is AHJ's call.
    No it's not. The NEC tells you how to calculate MCA and MOCP. The article you linked doesn't follow the NEC requirements.
  7. #27
    Join Date
    Feb 2013
    India
    Posts
    2,713
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for your response. I wonder whether i)NEC distinguishes between air conditioner and chiller and ii)UL or third party certifying authority would pass a product design also based on this article and so the AHJ because there is no violation of intent of NEC ie there is no danger to life and property.
  8. #28
    Join Date
    Feb 2003
    Connecticut
    Posts
    3,534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No (except for the special provisions for room air-conditioners.) It distinguishes between motor operated equipment with a heretic refrigerant motor-compressor and equipment without.
    Nobody would pass a product design based on this article. It's just an article, and not a very good one.
  9. #29
    Join Date
    Feb 2013
    India
    Posts
    2,713
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry, it is not clear how the article is not applicable to ''chillers''.
    UL or other third party certifying agency would test such a product design anyway for any danger to life and property. There would be none.......
  10. #30
    Join Date
    Feb 2003
    Connecticut
    Posts
    3,534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It doesn't mention "chillers" anywhere in the article. Where would you find a chilled water chiller?
    They would test a product to UL standards, not to what this article says.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
