User Tag List
Results 1 to 8 of 8
Thread: URD direct burial to from house to outbuilding
  1. #1
    Join Date
    Feb 2007
    Alexandria, VA
    Posts
    461
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I happened upon this installation. URD with a separate THHW conductor are direct buried in a trench to an outbuilding with a main panel inside the structure. Is this the best option? Is there a USE cable with four conductors available for this situation?
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2003
    Posts
    11,224
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The THWN is fine if that is conduit all the way, but not for DB as you've indicated. I've buried a separate USE bundled up with the triplex on occasion
    Yes, they make a 4 wire version of what you have but you may need to remark the cable to indicate the EG and Neutral.
    Tom
    TBLO
  3. #3
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,602
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Note: URD is not an approved NEC wiring method but your picture indicates at least one of the conductors is USE-2 which is approved for direct burial and for use in a conduit.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  4. #4
    Join Date
    Jun 2003
    Posts
    11,224
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by augie47 View Post
    That is a common cabling and marking for the triplex he has pictured. The THWN is the oddball.
    Tom
    TBLO
  5. #5
    Join Date
    Jul 2005
    Tennessee
    Posts
    16,602
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    agreed.. I just noticed he referenced it as "URD" and wated to make sure he realized it also had an acceptable rating
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,277
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Since the EGC can (in most cases) be bare copper and still be direct buried, I have no issue with using copper THWN for the EGC here.
    I know some will probably disagree.
    If that green conductor is aluminum, I say it needs direct burial rated insulation.
    I live for today, I'm just a day behind.
  7. #7
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,778
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    I agree.
    If a GEC can be bare, I don't know why an EGC can't be buried THWN.
    4 wire mobile home feeder may have been a simpler choice for this installation, but I don't know the circumstances.
  8. #8
    Join Date
    Apr 2009
    Clarkesville, Georgia
    Posts
    2,385
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cow View Post
    Around here, SH's did not stock 4/wire until 15-20 years ago (because "nobody bought it", self-fulfilling statement), so I have seen and done similar installations
    Dave Ruth
Posting Permissions
  • You may not post replies
  • You may not edit your posts
