User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Lighted switches w/ CFL or LED loads?
  1. #11
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,496
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    The screw placement and energization on switches is not consistent enough to support that use.
    Nonetheless, they do exist.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  2. #12
    Join Date
    May 2019
    Chicago, IL
    Posts
    69
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Leviton has some with an LED light that needs a neutral (but then it doesn't rely on leakage current through a switch loop):
    https://www.leviton.com/en/products/6526-w
    The pilot light switches have been around for a while but they're the opposite of what you want for seeing the switch in the dark: the light is only ON when the switch is already turned on. They're most useful to confirm that a load is turned on that you can't readily see or have access to.
  3. #13
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,729
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by synchro View Post
    Leviton has some with an LED light that needs a neutral (... it doesn't rely on leakage current through a switch loop):
    I would say that's exactly what the OP is looking for.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
