User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Lighted switches w/ CFL or LED loads?
  1. #1
    Join Date
    Jul 2006
    Roughly 5346 miles from Earls Court
    Posts
    2,860
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    First time in years I've bought lighted switches (Leviton, from Big Orange); they're marked "Not for use with LED of CFL bulbs". Does that really matter? The old neon-lit switches used the leakage through the incandescent lamp to make them light- CFLs don't have enough? LEDs?
    The place I'm installing them doesn't get much use and still has a lot incandescent lamps so it shouldn't be a problem for a while, but maybe next year somebody goes and swaps out all the old lamps for LEDs.
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,056
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I don't know about cfl but an led lamp will glow faintly when the switch is off.
    If you don't think too good, don't think too much.
  3. #3
    Join Date
    May 2014
    Marlborough, Massachusetts USA
    Posts
    388
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    CFL's can do the same
  4. #4
    Join Date
    Jul 2006
    Posts
    2,860
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That's pretty much what I expect.... and it's just a little extra light to find help find the switch .
  5. #5
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    236
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You need a switch plate with a built-in night-light. Weren't there some mentioned here that just slip over the switch (or was it a duplex outlet) and use spring pressure to grab onto the screw terminals on the device?
    Do they make switches that need a hot lead just to make a night-light light?
  6. #6
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,301
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PaulMmn View Post
    It is for duplex outlets only. The screw placement and energization on switches is not consistent enough to support that use.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,339
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zbang View Post
    Does some company make one with a neutral connection? That would solved the problem of of not having an incandescent type lamp in series with the lighted switch.
    Rob
  8. #8
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,712
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I commented in that thread about the switch/receptacle night lights. With the receptacle night lights still in my head (that are always on) I was thinking about where they got the neutral from with the switch. Then the rusty gears started to turn in my mind and, DUH, HELLO! the night light is in series with the load just like any other switch with the light built in.
    -Hal
  9. #9
    Join Date
    Apr 2019
    Union, KY, USA
    Posts
    236
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You need one of these. Of course, you have to have hot + neutral in the box!
    There are some pretty pictures about lighted switches at https://willnicholes.com/cflswitches.htm
  10. #10
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,440
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    They would be the same as a lighted switch: bulb in parallel with switch, powered through load.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
