User Tag List
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: How to Protect Electrical Service from Flood Zone
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,578
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cow View Post
    I disagree.
    For reference, we just ran three 4 inch conduits into a basement 3' below the water table.
    If you have the hole cored properly, and use a linkseal, combined with polywater fst foam, there will not be an issue.
    https://www.polywater.com/product/po...-duct-sealant/
    http://www.cooperindustries.com/cont...orconduit.html
    My guess is said basement probably also has drainage tile, sump pump, fill near the wall is something that will drain easily, etc. and to a certain extent you don't really need a perfect seal.
    I live for today, I'm just a day behind.
  2. #22
    Join Date
    Jan 2007
    Posts
    4,211
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    True,
    That, and, I doubt the installing contractor ever actually knows just how good a seal they've made a couple of years after leaving the project.
    The best penetration into a basement below grade level is no penetration at all.
    JAP>
  3. #23
    Join Date
    May 2018
    United States
    Posts
    395
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jap View Post
    True,
    JAP>
    coming up from the floor in an enlarged sump chamber seemed alright to me, you just have to get there early to make it seem practical to most people.
  4. #24
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,546
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by BatmanisWatching1987 View Post
    Thank you for the help.
    What code section would I need to look up for maximum height for panels and disconnect when in a flood zone?
    Idk the specifics of where you are, but in my area it’s typically 12” minimum above flood plane. If this puts your disconnect over 6’-7”, a platform that meets minimum working space dimensions is required.
    Brought to you by Carl's Jr. ©
  5. #25
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,578
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brantmacga View Post
    But OP says this is in a basement, presumably in a basement in an area where flooding may be likely. That IMO changes things, and can depend on what measures are taken to prevent the basement itself from flooding.
  6. #26
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,197
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    There is no maximum height, just 6-7 to the center of the switch from platform,and accessible, and that can be on a second story. Keep in mind the service entrance conductors are unfused and there are limits on running them inside a building, which vary greatly by jurisdiction (or encase in concrete).
    Moderator-Washington State
    Ancora Imparo
Posting Permissions
  • You may not post replies
  • You may not edit your posts
