User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Switching a gfci receptacle??
  1. #11
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,389
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    What brand of GFCI receptacles trip after being re-energized?
    Rob
  2. #12
    Join Date
    May 2014
    Marlborough, Massachusetts USA
    Posts
    400
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    P&S
    Ooops.
    P&S trip after being energized the first time not re-energized.
  3. #13
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,753
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    P&S but they only do that when first energized.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #14
    Join Date
    May 2014
    Posts
    400
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    I tried to edit before your response
  5. #15
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,811
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    190524-1626 EDT
    I went to this site
    file:///Users/bradra2/Desktop/341082-RevB_GFCI-Instruction-Sheet-English.pdf
    I did not find any comment that first application of power trips the GFCI.
    What it does say is that you are to press the RESET button after application of power, and that the GFCI should reset.
  6. #16
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,736
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Agreed!
    They COME FROM THE FACTORY in the tripped state. When you install them you have to push the reset button with power on to activate them. After that I have never seen one trip upon reapplying power unless there was something wrong with whatever it powers.
    -Hal
  7. #17
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,811
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    190524-2432 EDT
    As I mentioned before one reason to ship in the tripped state is so that, if the GFCI is wired backwards, then it can not be reset. A very good safety technique that is automatic.
  8. #18
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,770
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hbiss View Post
    Agreed!
    -Hal
    Those p&s ones sure sound like they trip when they are first energized. What is that sounds then if they come tripped?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  9. #19
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,811
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    190525-0455 EDT
    Take a new one from the box and do a continuity test.
    Then apply input voltage with the GFCI in open space where you can easily hear and feel what happens.
    Remove power and check continuity.
    Depending upon what occurs it may be necessary to open the GFCI and see if you can determone what happens to produce any noise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
