User Tag List
Results 1 to 9 of 9
Thread: Solar System Battery Chargers
  1. #1
    Join Date
    Jan 2018
    California
    Posts
    46
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello All,
    I wanted to share a solar distribution setup I saw at a remote telemetry station and wanted to hear your thoughts. This telemetry station consists of a 48V solar panel feeding a charge controller which feeds a string of battery totaling 48Volts. There is a second load charger which "transfers" the energy from the same battery to the DC load. Both chargers are from the same vendor - Morningstar. I was wandering why they would use two battery chargers, instead of one battery charger and one power supply. I'd think a 48Vdc-48Vdc power supply would provide stable voltage for the load and filter out any "irregularities" on the input.
    Thoughts?
    Thanks,
    EE
  2. #2
    Join Date
    May 2011
    Posts
    5,463
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    My guess is either someone didn't know what they were doing or there is something you've left out or described incorrectly.
  3. #3
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,944
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Initial thought is the second controller could be:
    1. A DC DC converter to change or stabilize the battery voltage (48v bank will be between 46 and 60 volts)
    2. An inverter.
    3. Some sort of load manager/controller.
    4. A diversion charge controller where the first controller is used for it's mppt and/or DC DC converter capabilities and not charge control (seems unlikely from your description).
    But I don't believe Morningstar makes anything for numbers 1-3, so I think we are back to JB's response
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  4. #4
    Join Date
    Nov 2015
    CA, USA
    Posts
    790
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would say the "load charger"is not a charger but either a DC power supply or an AC inverter. Morningstar does make an inverter.
  5. #5
    Join Date
    Jun 2004
    Posts
    5,944
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pv_n00b View Post
    And it's a great little inverter with very low standby losses, but only for 12V . Maybe it's a 12Volt bank not a 48 as the OP thought.
  6. #6
    Join Date
    Jan 2018
    California
    Posts
    46
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greetings,
    The two devices in question are Morningstar TS-MPPT-60 and Morningstar TS-45. The system is indeed a 48VDC system.
    Thanks,
    EE
  7. #7
    Join Date
    May 2011
    Posts
    5,463
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The TS45 has a diversion feature so that's almost certainly what it's being used for.
    The MPPT-60 will be better at harvesting energy from the array, because its MPPT, but it does not appear to have a diversion feature.
    So someone wanted to utilize a diversion load when batteries were full but didn't want to compromise on energy harvest, and spent extra money to get both features.
    I think we figured this out.
  8. #8
    Join Date
    Jun 2004
    Posts
    5,944
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    .... unless it's being used as a load controller. those TS controllers are able to do 3 modes, one of them being load control. I don't know offhand how the load control functionality is used. You could download the manual and read about it.
  9. #9
    Join Date
    Jul 2009
    Mesa Arizona
    Posts
    277
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Many telecommunications systems use a -48V (positive is grounded), but the Morningstar controllers are for a negative ground system. It is possible to isolate the array and controller and then ground the battery negative. This works for the charge function, but not for the load if a low voltage disconnect is needed. A work around is often a second controller and a relay for load control. The second controller does not need MPPT.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
