User Tag List
Results 1 to 7 of 7
Thread: Retro Fit T-8 to LED
  1. #1
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,178
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Some advice on retrofitting T-8 to LED
    1. Some systems have the ballast removed, and LED lamps wired direct to the tombstones. Are there any listing issues with this?
    2. Use LED lamps that work with existing ballast...is this less efficient than a LED fixture with no ballast
    The retro fit is for T-8 Strip Lights.
    Thank you.
    Moderator-Washington State
    Ancora Imparo
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,534
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tom baker View Post
    They need to be wired as listed, and the re-wired label applied.
    2. Use LED lamps that work with existing ballast...is this less efficient than a LED fixture with no ballast.
    In my opinion, yes; how could they not waste power?
    I greatly prefer option #1 for any retro-fit.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,770
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I agree with Larry, it just seems like a bad idea to use the ballast, more losses and another failure point.
    I always questioned putting 120 to the tombstones though. But most ballast bypass tubes come with new tombstones, fwiw.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  4. #4
    Join Date
    Mar 2003
    New England
    Posts
    13,938
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The LED tubes that work with ballasts are great for quick and easy retrofits, in fact there's a lighting company here that retrofits your current system with new T8 ballast and LED tubes.
  5. #5
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,534
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I haven't replaced tombstones on either a T-12 to T-8 conversion or an LED conversion. Why does it seem to be an issue?
    Larry B. Fine
    Master Electrician
    Richmond, VA
  6. #6
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,538
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Always do a ballast by-pass. I've got customers who did the lamp-swap only to save money up front, but now they're paying for it in ballast replacements.
    Quote Originally Posted by electrofelon View Post
    .........I always questioned putting 120 to the tombstones though...........
    Egads..... every tombstone I've ever seen is rated for 600 volts. Besides, have you ever looked up the voltage output of a ballast?
  7. #7
    Join Date
    Jun 2004
    Posts
    5,770
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    Yes I know the ballast has a higher voltage. Just wondering if perhaps they aren't rated for the current, and the available short circuit current. Don't get me wrong, I do it and don't lose sleep over it, just a curiosity.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
