User Tag List
Results 1 to 2 of 2
Thread: Changing NOVAR Controlled Lighting Schedules
  1. #1
    Join Date
    Sep 2006
    Appleton, Wi
    Posts
    495
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm working on a project that took over a big box store that has a NOVAR lighting control system. I'd like to make some adjustments to the switching times for the lights, but I have no experience with NOVAR systems. A quick search on the interwebz said that NOVAR is a licensed system and the end user needs to purchase a license to use (or make adjustments) to their system. I'm hoping I'm wrong and that there's a simple program I can throw on my laptop and plug into the NOVAR panel and make the time adjustments.
    It's a NOVAR Savvy Panel with a XCM10S controller.
    Any help is greatly appreciated.
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,822
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    A quick look at NOVAR shows me why they restrict access to their certified techs and not just anybody who thinks they can throw a program on their laptop to make some adjustments.
    If indeed the system is licensed to the user then your customer needs to purchase a license to use the system and then have a NOVAR tech make the changes.
    ETA: Another search might indicate that NOVAR isn't around anymore and a certified contractor might be hard to find. Looks like the solution is to change it out or upgrade to another system.
    https://hvac-talk.com/vbb/showthread...ace&styleid=41
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
