User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: EP in small residential 'wiring' closet
  1. #11
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    19,581
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Barbqranch View Post
    To make the 30 inch opening, though, the door should be a 2868. That would be nominally 32 inches wide, leaving plenty of room for the stops and hinges.
    Would it not have to be 2872, or some similar designation that assures 72 inches of height while standing in the doorway?
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  2. #12
    Join Date
    Jul 2013
    Arcata, CA
    Posts
    458
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    68 refers to 6 foot 8 inches.
  3. #13
    Join Date
    May 2017
    SCV Ca, USA
    Posts
    598
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by charlie b View Post
    72 inches (6ft) is not a standard residential door height. Save for a repurposed attic room for the college kid who moved back with mom and dad.
    The 2872 is a door chart for door hangers.
    2872 is equal to 32 inches wide by 7 ft 2 inches high.
    28 is 2 ft 8 inches while 72 is 7 ft 2 inches.
    Think rebar chart.
    Construction steel workers call the sizes in whole numbers.
    Sizes are in eighth of an inch increments (eg #3 is 3/8, #5 is 5/8. . .#8 is 8/8 0r 1 )
  4. #14
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,534
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by myspark View Post
    Just like fluorescent tubes.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #15
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,753
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    The door is designated as 2668. If that were inches, then it would only be 5 foot 8 inches tall, rather than 6 foot 8 inches. To make the 30 inch opening, though, the door should be a 2868. That would be nominally 32 inches wide, leaving plenty of room for the stops and hinges.
    I agree a 20 door is 2'0" or 24" so a 2668 is a 2'6" x 6'8" or 30" x 80". Given that and assuming that is in front of the panel then IMO the install is compliant
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  6. #16
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,527
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wouldn't let you install it in a closet. Even if you call it a wiring closet. Then every one with a panel in a closet can sat that's a wiring closet
  7. #17
    Join Date
    Mar 2003
    Vermont
    Posts
    2,525
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    well.....i suppose i'm a 'closet spark' then....
    today's gem...>
    ~RJ~
  8. #18
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,534
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by romex jockey View Post
    today's gem...>
    Wow.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #19
    Join Date
    Mar 2003
    Vermont
    Posts
    2,525
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It's my daily dose from the 'land code forgot' Larry.....~RJ~
  10. #20
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,753
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Yeah that would not fly around here. Violation for sure
Posting Permissions
  • You may not post replies
  • You may not edit your posts
