User Tag List
Results 1 to 4 of 4
Thread: PNL BUS/BRKR RATING
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,581
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PNL BUS/BRKR RATING
    In what situation would a panelboard have different amperage for the MCB and the bus? Most times I see them the same but do remember them being different once in while? Thanks.
  2. #2
    Join Date
    Dec 2011
    Wisconsin
    Posts
    681
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Some panels have a 200 amp MCB with 225 amp bus. I believe in some cases it is cheaper for a manufacturer to make one bus and use it in multiple panelboards.
  3. #3
    Join Date
    Jul 2006
    Posts
    8,861
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by packersparky View Post
    Actually in all cases. Panel bus sizes are only going to be among a few ratings, different from one mfr to another. 60A, then 100 or 125A, 200/225/ 250A, 400A, 600A, 1200A etc. So if you need a 90A main breaker your panel bus is going to be 100A or 125A, depending on the standard product your selected mfr uses. If you need a 300A main, its going to be a 400A bus, etc.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,943
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    This comes up in solar a lot. I agree manufacturers use the same bus for different main breakers, but the manufacturer rarely will tell you or document this.
    I had some 125 and 250A Siemens factory MLO panelboards and they were exactly the same. I took one of each out of the box and was looking over them and I mixed them up and couldn't tell which was the "125" and which was the "250"
    Edit. Just wanted to be clear that you can factory order whatever you want
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
