User Tag List
Results 1 to 3 of 3
Thread: Residential cabinet lighting recommendations?
  1. #1
    Join Date
    Jul 2005
    (44.057116, -123.103394)
    Posts
    540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greetings all I am curious what you all are using or specifying for in cabinet lighting these days.
    I am looking for something in particular that can be controlled on its low voltage side by a low voltage door switch or magnetic switch.
    We typically have been using Satco stuff but it is not controllable on the low voltage side.
    Does anyone have any experiences with lightkiwi?
    https://www.lightkiwi.com/
    It looks to be 24 Volt DC on the low voltage side which is interesting.
    Thanks in advance
    Comments based on 2017 NEC unless otherwise noted.
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,731
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Check GM Lighting, too. They have good phone support.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jul 2005
    Posts
    540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Thanks Larry these look good
    http://gmlighting.net/24VDC_SlimEdge_Modular_Lighter
Posting Permissions
  • You may not post replies
  • You may not edit your posts
