User Tag List
Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 73
Thread: General use receptacles on 30amp circuits
  1. #21
    Join Date
    Jan 2011
    United States
    Posts
    9,362
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by LarryFine View Post
    I had said:
    But are you going to see 4,400 to 4,600 watts of load on it? Doubt it.
    Ultimately 20amp OCPDs would be used, but the real world is different.
  2. #22
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,723
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mbrooke View Post
    To help us understand your thoughts a little better, why would the same not be able to be said about any device on any circuit?
    Why not ask: "Why shouldn't we be able to wire 15/20a receptacles on a 60a circuit?" What's different in your example?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #23
    Join Date
    Jan 2007
    Posts
    4,211
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But, couldn't we apply that train of thought to most any Device/OCPD combination if we wanted too?
    Why try and reinvent the wheel?
    Jap>
  4. #24
    Join Date
    Jan 2011
    United States
    Posts
    9,362
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    A short circuit might melt the plug to appliance flex cord before the breaker trips, if at all.
  5. #25
    Join Date
    Jan 2011
    United States
    Posts
    9,362
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by jap View Post
    Jap>
    Unfortunately reinventing the wheel is the norm
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	power layout 1.jpg
ID:	23123   Click image for larger version.
Name:	power layout 2.jpg
  6. #26
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,723
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Same with a lamp cord on a 30a circuit.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  7. #27
    Join Date
    Jan 2011
    United States
    Posts
    9,362
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    But not for a 20?
  8. #28
    Join Date
    Jan 2011
    United States
    Posts
    9,362
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Jap>
    Ignore "special purpose" its a office cubical receptacle
    Attached Images Attached Images
  9. #29
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,723
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    But not for a 20?
    I'd rather see a #18 on a 20a breaker than on a 30a.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  10. #30
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,723
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Is this a question about the #10 neutral some partition wiring includes?
    Or do you want to reduce the quantity of circuits to feed cubicle wiring?
    Larry B. Fine
    Master Electrician
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
