User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Occ Sensor Control Wiring in same conduit with 277 volt lighting circuit?
  1. #1
    Join Date
    Nov 2015
    MN
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I understand that if it's 0-10v dimming circuit, it's considered class 1, and needs to be separate from power conductors....but how about the "low voltage" control conductors going to an occupancy sensor?
  2. #2
    Join Date
    Nov 2015
    MN
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry....for clarification...I believe the 0-10v dimming conductors are considered class 2 circuits. My previous post said class 1.
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,496
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The LV occupancy sensors that we install are Class 2 so their conductors cannot go in the same raceway as the power conductors. Some 0-10 volt lighting control can be reclassified as Class 1 and occupy the same raceway as the power conductors.
    Rob
  4. #4
    Join Date
    Nov 2018
    New Orleans, LA
    Posts
    20
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can put low voltage wiring in the same condiut as power conductors as long as the low voltage wiring is rated for 600V (i.e. you could use some #14 THHN)
  5. #5
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,821
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Johnhall30 View Post
    That is not correct.
    -Hal
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,496
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That's a common misconception, Class 2 circuits that cannot be reclassified as Class 1 cannot be in the same raceway regardless of the voltage rating of the conductors.
    Rob
  7. #7
    Join Date
    Nov 2015
    MN
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ...unless it's in luminaire cable! I wonder how that is acceptable?
  8. #8
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lbartowski View Post
    That is acceptable because of the separate jacket around the Class 2 conductors.
    The argument is similar to the argument that two sets of wires, each inside their own EMT or Smurf tube, do not create a violation when those two raceways are run through a common enclosing raceway.
  9. #9
    Join Date
    Nov 2015
    MN
    Posts
    18
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Right, but is luminaire cable really 2 separate raceways just because the control cable is jacketed? That logic would seem to allow me to pull a jacketed control cable (like an 18/3) within an EMT with 277 volt circuits then right?
  10. #10
    Join Date
    Dec 2012
    Posts
    20,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Right. If the control cable is a self-contained wiring method that does not require a raceway, it should be able to share the enclosing raceway. But without the explicit UL listing that luminaire cable has, an inspector may not agree.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
