User Tag List
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 49 of 49
Thread: Sleeves
  1. #41
    Join Date
    Feb 2003
    Fl
    Posts
    17,756
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Wimp!
    I'm getting old.
    Roger
    Join Date
    Mar 2003
    Vermont
    Posts
    2,612
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    1st, thx for all replies, good insight.... 2nd, returned to the job today (monday) to find weekend warrior diggers found/installed my pipe.....
    So...one end is made into garage panel via 2" w/LB & frosty.... other end is under what will be a wrap around deck....so here's what i did>>>
    that's 10-3 UF in 2" sch 40
    WWYD???
    ~RJ~
  3. #43
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,743
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Can you withdraw the wire from the wall? If so, cut off the MA, put on an LB, and reinstall the MA in the LB into the wall.
    Of course, you'd have to make the hole in the wall bigger. Hey, you asked.
    Who shot the mis-fired torpedo imnto the wall?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  4. #44
    Join Date
    Mar 2003
    Vermont
    Posts
    2,612
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    [QUOTE=LarryFine;2003848]
    I could , but w/out a frosty it'd not last long....
    ah, that's a gas furnace vent....going to be a wee bit of a distraction on a deck .....
    ~RJ~
  5. #45
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    794
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    [QUOTE=romex jockey;2003915]
    Don't know "frosty", ... what is it?
  6. #46
    Join Date
    Mar 2003
    Vermont
    Posts
    2,612
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    [QUOTE=oldsparky52;2003917]
    Quote Originally Posted by romex jockey View Post
    sorry.....pvc expansion joint ......
    ~RJ~
  7. #47
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    794
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just never heard it called "frosty" (you didn't need to look up a pic )
  8. #48
    Join Date
    Mar 2003
    Vermont
    Posts
    2,612
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    frosy....slip joint....exp fitting.....thank God my supplier is multi-lingual ~RJ~
  9. #49
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,468
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I hate to ask but why would conduit be needed at all. That's UF cable. Come up the outside of the footer and into the Garage through the bottom of that seal. Kind of where it is now except with entrance from the bottom. Cable won't be exposed to physical damage. Nail guard where you drill the seal.
    The 95% of people that you can't trust give the other 5% a bad name.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
