User Tag List
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
Thread: Motor run in reverse?
  1. #1
    Join Date
    Nov 2004
    Posts
    284
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So if you reverse the polarity on a motor, it runs in reverse, right? Well, what about if that motor runs off 220v? What happens if you reverse a hot and a neutral, but the other hot wire is where it is supsed to be?
    Also, what about stuff you plug in? Like a vacum, or a garbage disposal...if the hot/neutral are revesed on the receptacle, do they run backwards, too?
  2. #2
    Join Date
    Apr 2003
    Posts
    5,156
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Motor run in reverse?
    To make a single phase motor go backwards you reverse the brushes. The leads are accessible on some motors.
    Sam, San Francisco Bay Area
  3. #3
    Join Date
    Feb 2003
    Posts
    898
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, reversing polarity will not reverse rotation of a single phase motor.
    You should never see a neutral wire connected to a motor.
    Obviously, this only applies to brush type motors.
    The vast majority of single phase motors are induction motors.
    For most of these, interchange the start winding leads. These will normally be red and black, or they will be numbered 5 and 8.
    Three phase motors are reversed by interchanging any two of the supply conductors.
    Ed
    [ January 03, 2005, 07:46 AM: Message edited by: Ed MacLaren ]
  4. #4
    Join Date
    Oct 2003
    Pennsville, N.J.
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The following is how you would reverse a 120-volt or 240 volt split-phase motor.
    Reverse the Start-Winding leads or the Run-Winding leads, but not both. This will reverse the direction of rotation for a split-phase motor.
    To reverse the direction of a three-phase induction type motor, you can reverse the leads in the starter. T-1, T-2, T-3. For example: Reverse T-1 and T-2, or Reverse T-1 and T-3, or Reverse T-2 and T-3.
  5. #5
    Join Date
    Feb 2003
    Posts
    898
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But, be careful if you try to reverse most dual-voltage motors by interchanging the run-winding leads.
    There are two "sections" and both will have to be reversed in relation to the start-winding, to maintain correct run-winding polarity.
    Ed
  6. #6
    Join Date
    Nov 2004
    Posts
    3,610
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Universal Motor:
    Someone mentioned brushes. Brushes and commutators are used on the "Universal" motor which is similar to a series wound DC motor but designed to run on AC or DC. This motor is used in small appliances, portable electric tools, etc. When you run your drill motor in reverse, you reverse the polarity of the field or the armature winding. This is not quite the same thing as reversing the polarity of the start windings on a split phase.
    There is also a permanent magnet DC motor which has no field winding. You merely reverse the polarity of the supply to reverse rotation.
    Oh, and synchronous motors use brushes and slip rings.
    Don't mess with B+!
    (Signal Corps. Motto)
  7. #7
    Join Date
    Feb 2003
    Posts
    898
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    WARNING - This is a test.
    The correct way to reverse the rotation of a synchronous motor is to interchange -
    a. the leads of the rotor winding.
    b. any two of the stator winding supply leads.
    c. the leads of the field winding.
    d. any two of the leads between the field winding and the field discharge switch.
    Ed
  8. #8
    Join Date
    Nov 2004
    Posts
    3,610
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Give us a diagram so we can be crystal clear.
    [ January 03, 2005, 01:50 PM: Message edited by: rattus ]
    Don't mess with B+!
  9. #9
    Join Date
    Jun 2003
    Posts
    7,079
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, they will run the correct direction. For a single phase motor (with only two leads), the motor can't see any difference between the two leads. Remember, it is alternating current. So one lead is positive on one half cycle, and the other is postitive the other half cycle. The motor doesn't have any idea which lead is the neutral.
    On a single phase motor with a single winding, the magnetic field does not rotate, but it only gives a push then pull effect. The motor rotates in whatever direction it is given a push. This push is usually devoloped by a start winding.
    Steve
  10. #10
    Join Date
    Jul 2004
    Posts
    328
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ed, the only way to reverse a synchronous motor is to exchange any two stator leads. Rotor or field pole leads should be reversed every 6 months to minimize pitting on the slip rings.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
